Attic Carpet - Flooring - DIY Chatroom Home Improvement Forum
Old 01-23-2008, 12:35 PM   #1
bp2
attic carpet
I'd like to put down a carpet in my attic. The floor is 1/2 inch plywood on 16 in centers. The room will only be used as an overflow bedroom at holidays so I don't want to put too much money into it.
Is another 1/2 inch of plywood needed so that someone doesn't end up in the floor below?
What happens to carpet when it is laid down on a floor with no stretching or perimeter carpet strips?
I'm hearing, "Don't scrimp on the carpet pad." Does that still hold in any area that will get very little traffic throughout the years? We're retired and aren't looking for resale value - we just have to please ourselves, but we don't want to be stupid about it.
Suggestions are welcomed.
bp2
bp2 is offline   Reply With Quote
Old 01-24-2008, 03:44 PM   #2
How thick are the joists? (8,10,12...inch)
redline is offline   Reply With Quote
Old 01-24-2008, 10:50 PM   #3
Floorwizard's Avatar
do not use pad unless you plan on stretching the carpet.
The carpet will eventually wrinkle because of walking and such.
if you desire a loose lay then buy a plush poly carpet and cut to fit without pad.
Lots of people here in AK do it in cabins.
Floorwizard is offline   Reply With Quote
Old 01-25-2008, 06:14 AM   #4
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,030
The floor is 1/2 inch plywood on 16 in centers. Is another 1/2 inch of plywood needed so that someone doesn't end up in the floor below?
Ayuh,.......
Unless you're going to be entertaining Elephants wearing Stilletos,......
I Really Doubt anybody is capable of stepping Thru 1/2" plywood.......
Old 01-28-2008, 07:22 AM   #5
bp2
Redline - the joists are 2 x 10s.
Should the floor molding/trim be put down before the carpet is installed. The floor molding will consist of 3 pieces.
I've got a soft spot (maybe two) so I'll cut it (them?) out and replace w/ undamaged plywood before the stilleto dancing elephants arrive.
Attic Smell from A/C - I'm at wit's end! cidsamuth HVAC 19 08-23-2016 05:36 AM
Gaps at baseboards after carpet install cometbus Flooring 9 10-01-2007 07:48 PM
Carpet Glued On OLD linoleum-HELP gradlass Flooring 5 09-30-2007 08:26 PM
Carpet Nightmare The Nomad Remodeling 3 09-30-2007 08:25 PM
glued down carpet...can I cheat? Dusty Flooring 3 10-10-2006 05:18 PM
