Attic Bedroom - Carpet - Flooring - DIY Chatroom Home Improvement Forum
Old 02-03-2008, 12:22 PM   #1
attic bedroom - carpet
Lowe's guy recommended StainMaster carpet for attic bedroom because it cleans up better than other brands. Do you all agree with this?
Potomac101 is offline   Reply With Quote
Old 02-03-2008, 02:00 PM   #2
Rewards Points: 1,274
No. How are you going to stain a carpet in a bedroom? Stainmaster is a 3M product applied to ANY carpet. You can buy cans of it and spray it on any carpet you buy. After a professional shampooing or steam cleaning, the stainmaster properties are washed away and has to be reapplied.
LawnGuyLandSparky is offline   Reply With Quote
Old 02-03-2008, 11:58 PM   #3
Lawnguy,
Are you confusing this with Scotchgard (made by 3M)? Stainmaster is made by Dupont, and according to Lowe's, and it's built into the carpet and lasts for years.
Thanks,
potomac101
Old 02-04-2008, 09:19 AM   #4
Lawnguy,
Thanks,
potomac101
Whoops... yes you're right I am confusing the 2. At any rate, note that "Stainmaster" is a brand name, not a promise of a product features or performance. Pickup a white "Stainmaster" area rug and a white non-Stainmaster area rug, both will stain if you spill wine onto it.
At any rate, how much staining would you expect on a 3rd floor bedroom carpet? I assume to get to the bedroom one would have to go through the 1st and 2nd floors to get there. By that time, what could be left on a pair of shoes?
Old 02-04-2008, 10:27 AM   #5
Darylh's Avatar
I have herd good things from clients about the Stainmaster.
Darylh is offline   Reply With Quote
Old 02-06-2008, 11:36 AM   #6
Floorwizard's Avatar
stainmaster is a fiber type not a spray.
it is made from a type 6.6 nylon which is durable.
it has a carbon core so it will reduce shocking.
it has better stain RESISTANT qualities than non branded nylons.
Polyester carpet however it may not wear as well, it is naturally more stain resistant than any Nylon.
Floorwizard is offline   Reply With Quote
Old 02-06-2008, 03:33 PM   #7
The #1 thing to consider for a quality wall to wall carpet is DAMN GOOD PADDING. Do not ever install carpet on the 1/2 inch crap that's "included free..."
Old 02-06-2008, 04:01 PM   #8
Rewards Points: 150
Nice product knowledge man. Can I come work for you?
mike costello is offline   Reply With Quote
Old 02-07-2008, 09:48 PM   #9
quite honestly the difference between 1/2 and 7/16 6# rebond is not a huge amount although you make a valid point.
it is better to pick an 8# over a 6# for sure.
upgrading further is also available
attic carpet bp2 Flooring 4 01-28-2008 07:22 AM
Gaps at baseboards after carpet install cometbus Flooring 9 10-01-2007 07:48 PM
Carpet Glued On OLD linoleum-HELP gradlass Flooring 5 09-30-2007 08:26 PM
Carpet Nightmare The Nomad Remodeling 3 09-30-2007 08:25 PM
Mixing Hardwood, Carpet, and Laminate! reptilicus81 Flooring 3 11-25-2006 08:43 PM
