Attaching Toilet Flange, Marble And Concrete - Flooring - DIY Chatroom Home Improvement Forum
Old 09-04-2008, 08:15 AM   #1
jelly's Avatar
Rewards Points: 330
Attaching toilet flange, marble and concrete
How would I go about attaching a toilet flange to marble tile over concrete substrate?
Above my sub floor I have 1" of concrete / Ditra / 1/4" marble tiles.
jelly is offline   Reply With Quote
Old 09-04-2008, 08:49 AM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Not clear on what you are asking. Typically a toilet flange doesn't attach to the tile, it attaches to the drain components and then is screwed into the substrate, generally through the tile. The flange can sit atop the finished floor and that is preferable but not necessary all of the time. There are also flange extenders and additional wax seals can sometimes be used to build up for the connection of the toilet to the flange/drain.
Old 09-04-2008, 09:15 AM   #3
jelly's Avatar
Rewards Points: 330
I need to screw down my flange. I just finished tiling over 1" of concrete (radiant floor heat)
Do I need to get concrete screws or drill through marble, concrete and screw to the wood subfloor? of so, do I need any special bits?
Old 09-04-2008, 09:24 AM   #4
Tileguy
Bud Cline's Avatar
Rewards Points: 558
I would pass through the tile and concrete and screw the flange into the subfloor.
Old 09-04-2008, 09:49 AM   #5
Registered User
Termite's Avatar
Yes, aim for the subfloor. You need to use a masonry bit to drill holes through the tile, ditra, and concrete. The bit needs to be large enough to keep the threads of the screws from engaging the tile. Be sure not to drill down through the subfloor with the masonry bit, as the hole would then be too big. Use wood screws (probably #14 or so) to secure the flange to the subfloor.
Old 09-04-2008, 10:29 AM   #6
jelly's Avatar
Rewards Points: 330
Cheers
Old 09-04-2008, 06:13 PM   #7
Electric Radiant Heating
warmsmeallup's Avatar
Rewards Points: 150
I hope your radiant is at least 6" from the wax ring!?
www.comfortradiant.net
warmsmeallup is offline   Reply With Quote
Old 09-04-2008, 08:33 PM   #8
jelly's Avatar
Rewards Points: 330
Whoa! didn't even think of that! I think I am at least 6" away.
marble tile over existing slate and concrete flooring bullrage22 Flooring 13 05-19-2008 07:58 PM
Any sort of footing material to put under toilet? BradG Plumbing 3 12-18-2007 08:59 AM
