Old 11-17-2011, 09:43 AM   #1
Attaching luan plywood to subfloor
I'm installing vinyl tiles over an existing vinyl tile hallway. Which is better to attach luan plywood over the sub floor ring shank nails or screws? If screw what kind? Existing floor has 1/4" Masonite+1/8" vinyl tile on top of that I will add 1/4" laun plywood + 1/8" vinyl tiles. Not sure of the thickness of the floor underneath. I understand your not a fan of luan plywood but that's what I have to work with.
journeyman102 is offline   Reply With Quote
Old 11-17-2011, 10:17 AM   #2
Pro Flooring Installer
rusty baker's Avatar
I am sure that one of the vinyl "experts" will help you.
"I'm twisted, not sick. Sick implies, I'll get better"
Semi-Retired Installer
Installing since 1973
The Following User Says Thank You to rusty baker For This Useful Post:
journeyman102 (11-17-2011)
Old 11-17-2011, 08:17 PM   #3
Tileguy
JazMan's Avatar
I agree no screws, use the ring shank nails made for the purpose.
Pros use 9/16" 18 guage staples,
OH OH, isn't that too short? I thought, and the vinyl guys here have always used 7/8" staples. I haven't installed thin ply in many years, but I do have a staple gun made just for installing 1/4" and also luaun and they're coated 7/8".
every 4"-6" in the field and 1"-2" along the edges.
No wonder you go 1-2" at seams. In this case the staple would not even penetrate the subfloor.
Jaz
Tile 4 You LLC Troy, MI
KERDI Shower Specialist ... DITRA Installs ... Product-Method suitability consultation. I have NEVER made a mistake, I thought I did once...........but I was wrong! - PRODUCTS ADVERTISED WITHIN MY POST ARE NOT ENDORSED BY ME!
Old 11-17-2011, 08:48 PM   #4
Whatever you think.
Old 11-17-2011, 09:37 PM   #5
Tileguy
JazMan's Avatar
OH OH, I guess I caught you on the wrong night.
I'm just saying what I've noticed and what I used to sell for 1/4" underlayment and luaun. I believe they use 7/8" -1/4" crown for the job. I just went to my van to see what I had. Mine are actually 1 1/8" long. I think I bought those cuz I occasionally used to use 3/8" AC ply. Haven't installed 3/8" in 3-4 years. Duo-Fast is the brand. I didn't find a 9/16" in the Duo-Fast selection, but doesn't mean they don't make em.
So you're saying Armstrong says 9/16" is long enough? That means the staple is penetrating the subfloor about 3/8". What underlayment are you using under sheet goods? Hopefully not luaun, does anyone dare use that stuff these days?
Here's something I found on the subject;
With all underlayments,
the fastener should penetrate the underfloor by
3/4” (1.9cm), but not protrude through the underfloor
by more than 1/8” (3.2mm). If the underlayment is
being installed over an old floor covering, the thickness
of the flooring should be taken into consideration
when selecting nail and staple length.
Jaz
Old 11-17-2011, 11:40 PM   #6
Moderator
Yep, wow! http://www.apa-europe.org/Languages/.../PDF/R340G.pdf
Luan; http://www.fcimag.com/CDA/Archives/B...00000000141280
Gary
Clothes taking longer to dry?
Staples or screws on plywood subfloor? And other questions.... howdihi Flooring 1 08-18-2011 09:50 PM
how to fasten plywood to subfloor to even out floor height cmlcsu Flooring 11 11-08-2009 10:19 PM
Luan plywood staples under tile? former33t Flooring 3 10-15-2009 02:34 PM
Subfloor repair Dave321 Flooring 3 09-16-2009 09:59 PM
Hardwood Subfloor: OSB vs. Plywood vs. OSB + Plywood italoblu Flooring 2 07-31-2008 01:11 PM
