Asbestos In Old Flooring? - Flooring - DIY Chatroom Home Improvement Forum
Old 03-28-2011, 07:48 PM   #1
Asbestos in old flooring?
I recently purchased a bungalow built in 1965. The only carpeting in the house was found on the stairs. I began lifting this yesterday and found linoleum or vinyl flooring (rolled in sheets) covering the stairs and landings. Without thinking, I began to lift the flooring as well. I now have 4 stairs and a landing without carpet and partial vinyl or linoleum exposed. There is some grey backing, and some black adhesive. With some reasearch today I'm now concerned that there is asbestos in this.
Any suggestions for safe removal?
Would I be ok to stop the job, and cover this with new carpeting or new linoleum? Would I have to remove the rest or just cover it up? There is some chipping and separation, but no loose particles and it's probably not a 100% level.
Any help would be appreciated.
Helpmyhome is offline   Reply With Quote
Old 03-28-2011, 07:54 PM   #2
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 42
At the very least, the adhesive most likely contains asbestos. The lino probably does also. The only way to be sure is have it tested. Yes, you can cover it, with carpet. In fact that is probably the safest thing to do. In some places you can remove it yourself. If you were to remove it keep it wet so it doesn't become friable. I don't recommend that you remove it.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 03-28-2011, 07:58 PM   #3
Thanks Rusty.
Do I need to seal it, or install a subfloor or anything overtop to keep it contained, or could it be as simple as underpadding and a new carpet?
Old 03-28-2011, 08:13 PM   #4
Rewards Points: 42
Pad and carpet.
Old 03-30-2011, 05:14 PM   #5
Yes you can go over it, but you can also remove it safely. The only concern you should have is to keep it from being airborne. Thus don't sand it. You can use black mastic adhesive remover (gets ya nice and high, so vent well) but that removes the need to sand if you have any left. Also you can sprinkle concrete dust over it and remove any stickyness to the adhesive that remains.
IceT is offline   Reply With Quote
Old 04-05-2011, 06:25 PM   #6
So I had a corner tested, and the lab confirmed it's 39% asbestos. As mentioned I removed some of the linoleum in chips from the top 3 stairs and landing. I'm now wanting to cover this however, I don't think I like the idea of maintaining carpet...it's hard to vacuum on stairs. If I'm doing hard wood or linoleum do I need to seal the cracked flooring I made prior to installing a subfloor?
Botched asbestos removal in home... runfrombears General DIY Discussions 28 07-31-2012 10:21 PM
want to remove recent vinyl flooring over asbestos subfloor fabster Flooring 5 05-04-2011 02:59 PM
asbestos and flooring bjeweled Flooring 2 03-23-2010 06:57 PM
Flooring options over asbestos tiles clouds88 Flooring 1 07-16-2008 05:52 PM
asbestos problem with vinyl flooring darsunt Flooring 6 08-31-2007 02:47 PM
