Asbestos Flooring - Flooring - DIY Chatroom Home Improvement Forum
Old 12-03-2013, 05:09 PM   #1
asbestos flooring
I have a concrete floor with vinyl flooring which contains asbestos. Is there any solution for laying tile over the top of it?
nine is offline   Reply With Quote
Old 12-03-2013, 08:13 PM   #2
DIY staff
Rewards Points: 7,174
How well are they stuck to the floor?
If they are loose enough to peal off with a scraper then they should be removed.
If you can't get them off without breaking them--then you could safely bond ceramic tile ---
Let us know----
Old 12-04-2013, 09:40 AM   #3
It is a sheet vinyl product and is stuck down quite well. What steps do I need to take to attach the tile to the vinyl?
Old 12-05-2013, 06:32 PM   #4
DIY staff
Laying ceramic over well adhered sheet vinyl can be done---there is some risk of bonding failure--but I have done it a few times and did not have an issue.
First wash the old floor with a soapy water and ammonia mix--that will remove any wax --
Use a two part thinset--Kerabond and Keralastic is and example---this has the strongest bond that I have found---
Some modified thinsets will also work----I've always gone to the tried and true when facing a vinyl floor---Mike---
Asbestos in floor tiles if house was built in 1991? Jenry3 Flooring 8 11-21-2011 03:36 PM
Asbestos in vinyl flooring? Acesneverwin Flooring 1 08-04-2011 06:40 AM
Botched Asbestos Removal Several Years Ago...Remediation? vs1988 General DIY Discussions 10 08-16-2010 11:28 PM
asbestos and flooring bjeweled Flooring 2 03-23-2010 05:57 PM
New flooring over possible Asbestos Born141 Tiling, ceramics, marble 7 01-18-2010 04:49 PM
