Asbestos Encapulation - Flooring - DIY Chatroom Home Improvement Forum
Old 12-02-2010, 12:46 PM   #1
asbestos encapulation
I have asbestos tile I want to encapsulate with vinyl tile, what are the steps?
stanko is offline   Reply With Quote
Old 12-04-2010, 04:07 PM   #2
C W
The asbestos tile installed has probably been installed over an asphalt adhesive,therefore leaving it down is a good option. Use mortar base floor patch and 100% acrylic additive,trowel well mixed product over entire area to be installed.Let dry. Mix next batch with water and approximatly 1/4 acrylic additive. Trowling is kind of an art, you need a good flooring patch trowel to get it as flat as possible.Hand scrape filler after set becarful if sanding as a lot of products have crystaline cilica and you don't want to breath that in. This should work just fine as long as your existing tile is well bonded.
C W is offline   Reply With Quote
vinyl siding over asbestos?? Buckeyes97 Remodeling 12 08-21-2012 09:20 PM
ASBESTOS..... lots of questions. Dyoung Building & Construction 22 02-14-2012 05:15 PM
Asbestos in old vinyl floor taubel Flooring 3 08-19-2010 08:48 PM
Botched Asbestos Removal Several Years Ago...Remediation? vs1988 General DIY Discussions 10 08-16-2010 11:28 PM
asbestos & paint--let's talk. jaes Painting 4 08-10-2008 10:49 AM
