Asbestos Encapsulation - Flooring - DIY Chatroom Home Improvement Forum
Old 04-08-2009, 08:32 AM   #1
Just started to renovate my basement, when I removed the carpet (has been there for 10 years) I saw that there was 9x9 tiles which have been already removed, but could see the black glue still on the concrete. Some have told me that the adhesive material used for gluing the tile had asbestos in it and needs to be enclosed/encapsulated. I've done some research and there are a lot of product which do that (in form of paint coating) does anyone have any suggestions on what is the better product out there. or should I put plywood or Masonite over it.
any suggestion?
Thank you
Beton is offline   Reply With Quote
Old 04-08-2009, 08:55 AM   #2
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 82
What are you going to put down? That determines what you need to do with the cutback.
Old 04-08-2009, 09:40 AM   #3
I was planing to put back new carpet.
Old 04-08-2009, 02:00 PM   #4
Rewards Points: 82
I would just cover it back up with carpet and pad. If you don't disturb it and it was okay for 10 years, why change anything now?
Old 04-08-2009, 02:19 PM   #5
Rusty Baker thank you for the advice, I was thinking the same thing but I just thought since I'm removing the carpet it may disturb it, the carpet was not really glued but after so many years it's kind of stiking to the ground.
thanks
Old 04-09-2009, 11:55 AM   #6
Floorwizard's Avatar
This is best.....
Floorwizard is offline   Reply With Quote
Old 04-09-2009, 05:50 PM   #7
Send a message via Skype™ to Floorman6
Thumbs up
Good advice
Good advice
Floorman6 is offline   Reply With Quote
vinyl siding over asbestos?? Buckeyes97 Remodeling 12 08-21-2012 09:20 PM
Vinyl Siding Versus Painting Asbestos freedom_fighter Remodeling 3 02-27-2009 10:35 PM
Could there REALLY be asbestos in our ceiling stucco? jenhib Building & Construction 6 08-26-2008 02:33 PM
asbestos & paint--let's talk. jaes Painting 4 08-10-2008 10:49 AM
