Armstrong Vinyl Plank Over Asphalt Tile? - Flooring - DIY Chatroom Home Improvement Forum
Old 05-30-2012, 07:53 PM   #1
armstrong vinyl plank over asphalt tile?
Can I install the above mentioned flooring over asphalt tile? The floor is sound and therefore I don't want to pull it up. In the directions it says that you can install over resilient floor blow grade. Are asphalt tiles considered resilient? If so why would it not work below grade? I was also thinking about installing ceramic tile over the asphalt tile if the vinyl wont work.
oba97 is offline   Reply With Quote
Old 05-30-2012, 07:57 PM   #2
Rewards Points: 13,712
It should be fine. I know tile will not work, it will not stick to the old floor.
Another Knucklehead Considers Laying Tile Over Vinyl Flooring tacklingherlist Flooring 14 08-26-2011 11:13 PM
Help! Armstrong "luxury" vinyl tile installation BlueBSH Flooring 2 02-17-2011 08:27 AM
basement vinyl tile ltd Flooring 5 02-02-2011 10:28 PM
Konecto vinyl plank vs glue down vinyl VinylVixen Flooring 4 02-24-2010 09:54 PM
Tile over vinyl hmc Flooring 7 10-25-2005 11:05 PM
