-   -   armstrong vinyl plank over asphalt tile? (http://www.diychatroom.com/f5/armstrong-vinyl-plank-over-asphalt-tile-145409/)
oba97 05-30-2012 08:53 PM
Can I install the above mentioned flooring over asphalt tile? The floor is sound and therefore I don't want to pull it up. In the directions it says that you can install over resilient floor blow grade. Are asphalt tiles considered resilient? If so why would it not work below grade? I was also thinking about installing ceramic tile over the asphalt tile if the vinyl wont work.
joecaption 05-30-2012 08:57 PM
It should be fine. I know tile will not work, it will not stick to the old floor.
