Old 04-21-2012, 06:24 PM   #1
Armstrong Premier laminate from Sam's Club
Any experiences (good or bad) in regards to the Armstrong Premier laminate line? It appears to be a Sam's and/or Sear's exclusive product. I cannot find any reference to the product at Armstrong's website or which of their other products I can compare it to. Thanks.
Rustygaff is offline   Reply With Quote
Old 04-21-2012, 07:00 PM   #2
JetSwet's Avatar
It depends, it could be there overstock line from last year, therefore they will sell it to sams club. I can tell you that it's not the newest line they have and that's why you won't find research on that style. The fact that it's at stores like that it could have been somewhere else so check the boxes really well. Armstrong is a good line of flooring I think they have numerous styles just in the premiere line.
How much are they asking per box? What's the mm grade on it?
Are they selling the vapor barrier as well?
JetSwet is offline   Reply With Quote
Old 04-22-2012, 12:29 PM   #3
This is what I have found:
$ 2.04 per sq. ft.
  • 12mm thickness
  • G3 wear layer keeps your new floor looking new with protection against stains, fading and wear through
  • Magnum HDF Core provides an unbeatable moisture barrier
  • No glue; easy locking installation
  • 13.28 sq. ft. coverage per carton
  • Pallet quantity with 56 cartons covers 743.68 sq. feet
Old 04-23-2012, 02:24 PM   #4
JetSwet's Avatar
$ 2.04 per sq. ft.
[*]12mm thickness[*]G3 wear layer keeps your new floor looking new with protection against stains, fading and wear through[*]Magnum HDF Core provides an unbeatable moisture barrier[*]No glue; easy locking installation[*]13.28 sq. ft. coverage per carton[*]Pallet quantity with 56 cartons covers 743.68 sq. feet
It sounds about right for 12mm and some other. Bells and whistles. If you go for it just make shore you check all the boxes well.
Ditra under Laminate Floor? HECO Flooring 3 04-30-2012 09:00 AM
New Home with laminate floor from Armstrong DYJ Flooring 17 11-03-2011 06:58 PM
armstrong laminate/ pergo laminate asterias Flooring 1 11-15-2010 12:42 PM
Armstrong Commercial Laminate Katypiz Introductions 0 11-04-2010 09:31 PM
Counter top plastic laminate Gerry Kiernan Interior Decorating 4 10-13-2008 11:44 AM
