Armstrong Laminate Underlayment Question - Flooring - DIY Chatroom Home Improvement Forum
Old 11-21-2008, 08:09 PM   #1
Rewards Points: 199
We are planning to install about 350 square feet of Armstrong Nature's Gallery laminate in my kitchen and breakfast area. It's inexpensive off the rack from Home Depot. It has a thin green foam underlayment attached. I'm wondering if I should supplement the underlayment with the roll stuff? We will be installing this ourselves over well glued, even sheet vinyl which was installed over plywood subfloor. I looked at several local floor shops and this pattern is the stuff I like best. It looks like stone tile.
Arlo is offline   Reply With Quote
Old 11-22-2008, 11:39 AM   #2
Floorwizard's Avatar
Do not suppliment.
The tounge and groove is going to be too weak to deal with 2 layers of pad.
you will most likely have problems.
Floorwizard is offline   Reply With Quote
Old 11-22-2008, 01:51 PM   #3
Get out of the box!
Rewards Points: 260
He is very correct no extra pad is needed if use it could lead to floor failure.
Schluters Kerdi Shower System, Ditra. Loxcreens ProVa Mat Shower Systems
Konecto Luxury Vinyl Plank,Armstrong and Hardwood flooring.
https://IndianaFloorsLLC.com/default.aspx
26yrsinflooring is offline   Reply With Quote
Old 11-22-2008, 10:55 PM   #4
Rewards Points: 199
Thank you. It'll save some money too.
Counter top plastic laminate Gerry Kiernan Interior Decorating 4 10-13-2008 10:44 AM
LAMINATE STAIR: with or without underlayment nathan.tran Flooring 1 08-19-2008 01:24 AM
Laminate vapor barier underlayment question amdspitfire Flooring 4 03-21-2008 10:48 AM
Subfloor / underlayment question... scheenstra Flooring 7 02-21-2008 07:39 AM
Laminate floor underlayment Question toolman33 Flooring 4 02-12-2008 07:10 PM
