-   -   Armstrong Laminate Underlayment Question (http://www.diychatroom.com/f5/armstrong-laminate-underlayment-question-32361/)
Arlo 11-21-2008 08:09 PM
We are planning to install about 350 square feet of Armstrong Nature's Gallery laminate in my kitchen and breakfast area. It's inexpensive off the rack from Home Depot. It has a thin green foam underlayment attached. I'm wondering if I should supplement the underlayment with the roll stuff? We will be installing this ourselves over well glued, even sheet vinyl which was installed over plywood subfloor. I looked at several local floor shops and this pattern is the stuff I like best. It looks like stone tile.
Floorwizard 11-22-2008 11:39 AM
Do not suppliment.
The tounge and groove is going to be too weak to deal with 2 layers of pad.
you will most likely have problems.
26yrsinflooring 11-22-2008 01:51 PM
He is very correct no extra pad is needed if use it could lead to floor failure.
Arlo 11-22-2008 10:55 PM
Thank you. It'll save some money too.
