Armstrong Alterna Tiles Over Control Joint - Flooring - DIY Chatroom Home Improvement Forum
Old 02-17-2011, 02:44 PM   #1
Armstrong Alterna Tiles over Control Joint
I had the brother in law install some Armstrong Alterna tiles in my basement bathroom this weekend. I provided an underlayment type material that the store suggested which would allow me to pull up everything if I ever wanted to change the tile. This material seemed to be just a very thick paper type material and did not act as a vapor barrier.
He laid the material down on the concrete floor and then used the adhesive to install the tiles. After looking at the job, I noticed that a control joint goes underneath the area and that it falls directly underneath the middle of a tile row (not the grout joint). I'm wondering if this is going to be an issue since the underlayment is free floating over the concrete. I had not filled the control joint with anything such as backer rod and sealant.
Yankee1423 is offline   Reply With Quote
Ceiling Fan Speed Control czars HVAC 0 01-14-2010 08:06 PM
Driveway & Garage Floor Control Joint detailedEye Building & Construction 4 01-28-2009 09:37 AM
Old ceiling tiles - remove? repaint? sertiphyible Remodeling 5 08-24-2008 10:36 AM
concrete joint leaking billie_t Building & Construction 3 07-24-2008 08:10 PM
Control Arm - Self locking nut spins ball joint dkbaum Automotive Repairs 4 02-24-2008 11:56 AM
