Old 11-03-2011, 08:19 PM   #1
armsstrong fiberglass flooring
I am getting wrinkles all over in my floor. It was installed properly with the proper gap cut from the walls and the base was not installed tight to the floor. How do i shrink the wrinkles
Ruckusman is offline   Reply With Quote
Old 11-03-2011, 08:36 PM   #2
Pro Flooring Installer
rusty baker's Avatar
Pull it back and smooth it out as you lay it back down. Then if it's too long, retrim.
"I'm twisted, not sick. Sick implies, I'll get better"
Semi-Retired Installer
Installing since 1973
Old 11-04-2011, 05:39 PM   #3
"getting wrinkles" ? is the floor loose laid or glued? if the floor is loose laid then it may be shifting...... shift it back.
if its glued then how many wrinkles? are they large? a minor fix is to heat up the wrinkle and then press it down and leave weight on it overnight. anything further would require a pic and more detail.
HarryJ is offline   Reply With Quote
Lumber Liquidators Bud Cline Flooring 11 10-28-2011 03:00 PM
asbestos in our ripped up flooring?? 6fthook Flooring 16 07-30-2011 12:06 AM
Installing Hardwood Flooring on Concrete Flooring, Condo slickwilly789 Flooring 1 10-08-2010 09:53 PM
Installing engineered flooring in the Philippines Flt_Simulation Flooring 15 07-21-2009 09:00 PM
no glue, no nails wood flooring - little help? reds_21 Flooring 2 02-13-2009 12:32 PM
