-   -   armsstrong fiberglass flooring (http://www.diychatroom.com/f5/armsstrong-fiberglass-flooring-122306/)
Ruckusman 11-03-2011 07:19 PM
I am getting wrinkles all over in my floor. It was installed properly with the proper gap cut from the walls and the base was not installed tight to the floor. How do i shrink the wrinkles
rusty baker 11-03-2011 07:36 PM
Pull it back and smooth it out as you lay it back down. Then if it's too long, retrim.
HarryJ 11-04-2011 04:39 PM
"getting wrinkles" ? is the floor loose laid or glued? if the floor is loose laid then it may be shifting...... shift it back.
if its glued then how many wrinkles? are they large? a minor fix is to heat up the wrinkle and then press it down and leave weight on it overnight. anything further would require a pic and more detail.
