Aren't 1-1/2" Staples Too Long For 3/4" Hardwood Flooring? - Flooring - DIY Chatroom Home Improvement Forum
Old 03-10-2014, 02:37 PM   #1
Rewards Points: 1,062
Question
Aren't 1-1/2" staples too long for 3/4" hardwood flooring?
The hardwood nailer I got (Numax) takes 15.5 ga 1/2" crown staples. All I was able to find in terms of length is 2" and 1-1/2" (Bostitch).
It appears to me that 1-1/2" staples would be too long for nailing 3/4" hardwood into 3/4" OSB subfloor. Because the part of the hardwood strip the staple would go through seems at most 1/2" diagonally (assuming 45 deg angle) and the OSB part maybe a little less than 1" (same angle assumption).
I would not like tips of staples to protrude on the bottom since there is basement on the other side and lots of wires and pipes, not that I think there is wire affixed anywhere to the subfloor above but I would prefer to not have a rough surface with nail tips.
I tried googling 15 ga 1/2" crown with 1" or 1-1/4" length but there wasn't any.
Can you tell me if my 45 deg angle assumption is incorrect and whether I can safely staple 1-1/2" staples into 3/4" hardwood + 3/4" subfloor?
Old 03-10-2014, 02:42 PM   #2
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 142
I wouldn't use 1 1/2" staples. If they blow through, you lose holding power. Since the staple goes in the tongue, it is going through less than 3/4" plus the subfloor.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 03-10-2014, 02:52 PM   #3
I understand and that was my concern. However, they don't make my size any shorter than 1-1/2".
Assuming a 45 deg angle, the length of the path would be:
[2 x (3/8)^2] ^ 1/2 + [2 x (3/4)^2] ^ 1/2 = 0.53 + 1.06 = 1.59"
which is a little more than the length of the smallest nail but still not much wiggle room for safety
Old 03-10-2014, 03:26 PM   #4
Tileguy
JazMan's Avatar
Rewards Points: 412
The "standard" for 3/4" is/used to be (?) 2" cleats. That's what I use, and what is recommended. The idea is to fasten through and into the joists and another between the joists.
That's not a good reason at all. Manufacturers want the fasteners to pock through the underside of the subfloor to verify how well the floor was installed in the event you had a claim. In some cases the 1st 1/4" doesn't do anything, has no gripping power.
Jaz
The Following User Says Thank You to JazMan For This Useful Post:
amakarevic (03-10-2014)
Old 03-10-2014, 03:34 PM   #5
I'm gonna go ahead and give 1-1/2" a try...
Tags
hardwood , staple
strand bamboo flooring over previously sanded/refinished hardwood flooring Prather Flooring 1 05-28-2012 05:05 AM
Hardwood flooring installation horsthelmut Flooring 9 05-12-2012 12:21 AM
Hardwood Flooring Repair pkyne78 Flooring 1 05-10-2012 04:19 PM
Hardwood flooring cupping Brian Lewis Flooring 14 12-06-2010 02:19 PM
Hardwood Flooring transition msfmatt Flooring 2 05-21-2009 07:57 AM
