Old 01-28-2007, 06:50 PM   #1
Unhappy Approach to demo bathroom ceramic tile floor for remodel
Beginning demo on a remodel of small 3/4 bathroom. Current floor is grouted ceramic tile over approximately 1" morter on plywood. The tile and mortar do not extend underneath the current base cabinet (so there is a depression).
The remodeled bathroom floor and shower walls will be finished in travertine tiles. The new sink base will be open to the new flooring below.
What is the best approach, remove all material (morter, tile and grout, down to the plywood?) or just pop up the tiles and fill in where morter is currently missing. If the answer is to remove the material down to the subfloor, any tricks to going about this?
corky is offline   Reply With Quote
Old 01-28-2007, 08:46 PM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
You could install cement board into that area of the floor. Use the cement board to build it up to the point (measurement) you want. You could also use plywood under the cement board to take up any fractions of depth. Make sure that you use adhesives and screws if starting off with the plywood. After the cement board layer, apply thinset over all of it to even it out. (Obviously you should use the thinset when installing the cement board too)
If you do decide to remove it all, a simple and effective tool is a demolition hammer. It is slightly smaller than a jack hammer. You can rent these.
We have one and it paid for itself ($800) after about 3 jobs...
2 basement bathrooms and tearing up several tile floors.
- Build Well -
Old 01-28-2007, 11:22 PM   #3
Tileguy
Corky as you know, travertine is a natural stone product. But did you know that natural stone tiles require double the floor strength of ceramic tile? You will need to add plywood after removal of the tile and cement to meet this need. Trying to remove the tile only will more than likely result in damaging the cement beyond what it would take to support the travertine.
The demo hammer should make short work of removing it all, the vibration will work in your favor.
Old 01-29-2007, 11:59 AM   #4
About the Demo hammer: We use a spade tip for removing tile. Essentially, it is in the shape of a concrete type chisel. Instead of going thru and using a chisel and hammer manually. The demo hammer, with this attachement, does all the grunt work for you.
And as Bud Cline stated: The subfloor materials pretty much always get wrecked with it....But then you can put in a nice new solid subfloor...
- Build Well -
More On This Topic
Hi, I’m Faith and I’m with Flat Fork Studio, and I’m here to discuss the different kinds of adhesives that you might want to use in doing your tile mosaic project. There’s several different applications. You first need to decide... Read More »
Hi my name is Jeremiah Johnson; I’m the owner and operator of S&J Cleanaway. I’ll be demonstrating how to remove adhesives from a floor, this can also double for non-stick pads inside of a shower or bathtub or just anything that would... Read More »
Hi, I’m Faith and I’m here at Flat Fork Studio and I’m going to show you how to adhere tiles to a cement stepping stone using Liquid Nails. First you take your Liquid Nails. I use the heavy duty, construction, and remodeling adhesive... Read More »
Today I'll show you how to make this beautiful mosaic hand mirror. These are the materials we'll be using to make our mosaic hand mirror. You'll need an assortment of crockery that you can break, either you can find this in second hand stores or just... Read More »
Now, I’d like to talk about the materials it takes to do these projects, some of the things that you are going to need to have if you want to get started. Of course you are going to need the ceramic tile adhesive, as I said, this is available at... Read More »
Ceramic tile over existing (full mud) ceramic? rjniles Flooring 7 12-24-2008 08:12 PM
stains on ceramic tile sdgoss Flooring 4 09-19-2008 08:19 PM
Preping for ceramic tile install leroyme Flooring 21 11-29-2007 05:31 PM
How do I remove this ceramic tile? tripower Flooring 5 07-23-2007 11:45 PM
Ceramic tile installed over resiliant tile ramsfanjeff Flooring 1 11-26-2005 04:26 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
