Old 10-28-2009, 10:12 PM   #1
Question Applying self leveling floor compound over existing floor adhesive?
Hi,
I just removed some 30 year old linoleum flooring and the floor adhesive is still on the concrete slab. I'm installing tile so I want to get it right. I wanted to know if self leveling floor compound can be applied over the existing floor adhesive or do I have to go ahead and scrape it off? If so, any tips on what is the best way to remove the adhesive?
rortiz is offline   Reply With Quote
Old 10-29-2009, 12:29 AM   #2
Tileman-Manufacturers rep
We need to know more about this adhesive. What color, how thick a film, feel hard, sticky, how old, does hot water do anything? What does it say on the product you plan to use? Do you need to level the floor or make it flat?
Irrespective, you do have to scrape the floor until most or all is off, just need to know more to determine if it all has to come off or not.
Jaz
Tile 4 You Inc. Troy, MI
KERDI Shower Expert...DITRA Installs...Containers of TRAVERTINE Direct from Turkey Quarry...SAVE 40-70%
Old 11-05-2009, 04:54 PM   #3
Don't know the adhesive, but when i pulled up the linoleum, there was like a gray cotton-like material under it. Some of it came off with the linoleum, some did not. I'm assuming it's the backing of the linoleum. I heard it might have asbestos so I'm using a wet method to remove it. Almost done taking it all off. Some yellowish-white adhesive still remains. Comes off fairly well with hot water but still wanted to know if i can apply the self leveling floor compound on top of it. Days are getting colder and i need to finish quickly.
Old 11-05-2009, 10:41 PM   #4
Tileguy
The yellowish is the old adhesive and the whitish is likely from the moisture you are applying. The whitish also may indicate the use of a water-based adhesive to install the vinyl (linoleum) originally. At any rate you must remove the old adhesive to nothing more than a stain remaining. THEN use the primer associated with the self leveller you choose to use. Installing self leveller over a thick residue of old adhesive (especially if it is water-based) will be counterproductive and may cause the self leveller to peel and lift.
More On This Topic
Installing new vinyl flooring is an inexpensive way to improve the look of a room, especially kitchens, bathrooms and laundry rooms. You can save quite a bit of money by installing the vinyl floor yourself. The most difficult step is applying the... Read More »
Hi! This is Steven from Keilholz Flooring on behalf of Expertvillage.com. In this segment, I am going to show you how the apply the adhesive for your new floor installation in your basement. The first thing I want to do is because I am working in a small... Read More »
Hi! This is Steven from Keilholz Flooring on behalf of Expertvillage.com and now I am going to show you how to put the material back into the adhesive. You are going to start up by rolling the material slowly back into the adhesive. Making sure to try... Read More »
We're about to apply the prosthetic chin on our model. I've put the adhesive already on her skin and now I'm going to put it on the back of the adhesive itself. These are very basic techniques. There is much more advanced ways to do this, but this is a... Read More »
A small hole in a wall is an unsightly nuisance. If the hole is less than 3 inches in diameter, you can easily repair it with an aluminum patch kit. Repair kits typically come with a 4-by-4 inch adhesive aluminum patch, spackling compound, sandpaper and... Read More »
New Roof and Insulation over Existing Roof MitchellScott Roofing 1 05-03-2009 10:24 AM
Leveling an existing interlocking wall dabob Building & Construction 2 05-02-2009 08:12 PM
Replacement Aluminium Window - Reusing existing sill flashing? GrantJohnson Building & Construction 1 01-26-2009 11:07 PM
Portland based self leveling underlayment under travertine floors Keith Carlson Ceramic Flooring 7 01-25-2009 05:58 PM
Blending ceiling patch with existing sheet-rock (slight texture) gmhut Painting 3 07-29-2008 01:16 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
