Applying Adhesive For Commercial Floor Tiling - Flooring - DIY Chatroom Home Improvement Forum
Old 11-10-2011, 12:30 PM   #1
Rewards Points: 1,062
Question
applying adhesive for commercial floor tiling
i have a small area in which to set some commercial floor tiles (Armstrong). i was wondering how to apply the adhesive. should i use a tiling trowel for the floor to ensure an even amount everywhere or a regular putty knife is OK? i am concerned to not be able to get the adhesive off my tiling trowel.
thanks
Old 11-10-2011, 03:45 PM   #2
Tileguy
JazMan's Avatar
Rewards Points: 422
You forgot to say which adhesive it is. OK, definitely not a putty knife. You need a trowel with the correct notches to it leaves the correct amount. It's also likely that the adhesive may be a brushable type. So cheap brush or roller.
Jaz
Old 11-10-2011, 03:52 PM   #3
Tileguy
Bud Cline's Avatar
Rewards Points: 558
May not want to use notches, may just need a wavy-edged trowel. Some trowels cost about two bucks, use it and throw it away.
XXX
Old 11-10-2011, 03:54 PM   #4
Handyman
Rewards Points: 512
I agree with Jazman..putty knife is not good. If its VCT and you are using a standard mastic adhesive I would go with a 3/16 x3/16 V-notch trowel. Make sure you have a pail of water and a sponge readily available for clean joints
canadaclub is offline   Reply With Quote
Old 11-10-2011, 03:56 PM   #5
Tileguy
Bud Cline's Avatar
Rewards Points: 558
WHOAH THERE!
You definitely don't want to use a 3/16" notched trowel with VCT tile.
NO WAY.
XXX
Old 11-10-2011, 04:29 PM   #6
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 180
1/16 x 1/32 x 5/64 U notch trowel.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 11-10-2011, 04:40 PM   #7
Tileguy
JazMan's Avatar
Rewards Points: 422
Thanks for agreeing with me, but........................3/16" is way too much. You'd have adhesive oozing between the seams and dents all over. Use the one Rusty recommends, or brush. Apply thin, let dry until tacky, then set tiles.
Jaz
Old 11-10-2011, 05:02 PM   #8
Handyman
Rewards Points: 512
EEK! I stand corrected..thanks guys. At least I prompted more answers
Old 11-10-2011, 06:00 PM   #9
Here we go: Armstrong S-750
picture attached (can looks different from the one on their web site)
http://www.armstrong.com/flooring/fl...duct-50750.asp
applying adhesive for commercial floor tiling-commercial_flooring_adhesive_x.jpg
Problems with Omni Grip tile adhesive Blue Flooring 24 05-15-2016 07:37 PM
Basement Flooring Question - Cutback Adhesive Atskodinski Flooring 5 12-11-2010 01:48 PM
floating laminate over old adhesive jbitt Flooring 3 09-27-2010 04:58 PM
Applying self leveling floor compound over existing floor adhesive? rortiz Flooring 3 11-05-2009 08:41 PM
What type of adhesive should I use to glue down accoustical cork to a concrete floo Fixitgeorge Flooring 2 03-20-2009 07:54 AM
