#1 |
Applying 3/8 plywood on top of 3/4 wood planks??
My subfloor is made of 3/4" wood planks from back in the days. I want to place 3/8" plywood on top for a more solid floor and less creaking. This will give me a 1 1/8" thickness. What size nails should i use to nail down the plywood if I want it to reach the joists?
Thanx.. Some areas will take screws while others will be nailed down, wanting to know both sizes.. Thanx |
#2 |
min 1.5. 2 inchs would be better. screws or nails
#3 |
Tileguy
What will you be installing in this room? What type, size, spacing are your joists? What is the unsupported span? Do you know the species and grade?. If you're going with tile, you need answers to all these questions.
Jaz
Tile 4 You LLC Troy, MI KERDI Shower Specialist ... DITRA Installs ... Product-Method suitability consultation. I have NEVER made a mistake, I thought I did once...........but I was wrong! - PRODUCTS ADVERTISED WITHIN MY POST ARE NOT ENDORSED BY ME! |
| Display Modes | |
| Ready to paint the porch! Oil or latex? | Leah Frances | Painting | 8 | 07-26-2011 08:29 PM |
| "Defogging" double-pane windows .... a gimmick?? | alexz | General Discussion | 133 | 03-10-2010 01:35 PM |
| Nailing down engineered wood planks ? | Flt_Simulation | Flooring | 2 | 05-14-2009 05:36 PM |
| flooring | frankiedog | Flooring | 7 | 12-05-2008 02:05 PM |
| Do I need to replace a rotten sill plate | met | Carpentry | 8 | 07-11-2008 10:14 AM |
