Anyone Used Delta Fl Or Superseal With Vinyl? - Flooring - DIY Chatroom Home Improvement Forum
Old 11-11-2009, 10:50 AM   #1
Rewards Points: 26
Anyone used Delta Fl or Superseal with vinyl?
Has anyone used Delta FL or Superseal in basements as a primary underlayment with a vinyl floating floors like Allure?
I'm wondering about 3 things:
Do either of these roll outs offer much insulation value on a cold basement floor?
Are there any moisture problems with them using vinyl flooring?
Do you need OSB or something else before you lay in the vinyl to prevent too much flex, protect against moisture, etc?
Thanks.
Jeff
jefferis is offline   Reply With Quote
Old 11-11-2009, 10:54 AM   #2
Framing Contractor
Thanks.
Jeff
Check into "Dricore". It work out for you.
http://www.dricore.com/en/faquest.aspx
Joe Carola
Joe Carola is offline   Reply With Quote
Old 11-11-2009, 11:00 AM   #3
Rewards Points: 26
I asked about dricore in a separate post. How much insulation does it offer over a cold basement floor?
seal seams on self sick tiles NoExperience Flooring 3 08-12-2008 07:25 PM
vinyl sheet or tile (or allure) over old vinyl? thomase Flooring 8 06-30-2008 05:15 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 12:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 03:35 PM
