Anyone Familiar With 'Jet Coating' Brand Deck Coating? - Flooring - DIY Chatroom Home Improvement Forum
Old 05-13-2011, 06:16 PM   #1
Rewards Points: 682
Anyone familiar with 'Jet Coating' brand deck coating?
We have some balconies that are coated with metal lath and acrylic modified cement. I remember the brand name of some of the materials used was 'Jet Coating'. We are located in southern california. Is anyone familiar with this brand?
I mention this because I cannot find them anywhere on the internet, and I've heard when maintaining these deck floor coatings it is important to use the procedures and products recommended by the manufacturer.
If I can't find the recommended product, I will probably just wash down the decks and apply some Seal Crete clear seal and hope that works.
darsunt is offline   Reply With Quote
Old 05-13-2011, 11:46 PM   #2
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 14
Might have better luck with this in the painting forum.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 05-17-2011, 11:54 AM   #3
Jet Coatings
Is located in LA somewhere, i don't think they have any retail stores carrying their stuff. Last time we used Jet Coatings "paint" it looked more like colored water and lasted about as long...
many stores in the OC/LA area carry Life Paint/Life Deck decking, a far superior product to Jet Coatings and many also carry Desert Brand sealers for decks and Magnesite. Again, far superior to Jet Coatings.
Another issue with Jet is their metal lath system is NOT an ICC approved decking product. If you have fire resistant decks/walkways, Jet is not proven to be a Class A roof/deck coating and you may be violating code requirements if you install it.
DeckExpert is offline   Reply With Quote
Old 05-18-2011, 12:27 PM   #4
Rewards Points: 682
deck expert,
We are stuck with the jet product (the work is done). Do products like desert brand sealers work well enough to maintain a balcony surfaced with jet coatings?
Also which specific stores carry such products? I know hardware stores don't carry it, paint stores don't.
Old 05-18-2011, 12:52 PM   #5
Jet Coating
Yes any sealer like life Paints 10 series or Desert Brand's CMFPS will work just fine. Call Life paint and Desert Brand for stores in LA/OC area that carry their products.
Old 05-19-2011, 11:07 AM   #6
Rewards Points: 682
How about a sealer, such as desert brand sealers?
Old 09-23-2016, 10:30 AM   #7
Rewards Points: 209
Re: Jet Coatings DECKING
What are some metal lath systems you or others recommend for repairing an old exterior cement deck. We removed some rail posts and need to repair sections.
Jet has EMC - "elasticrete magnesite cement" that can be mixed with Elasticrete latex (a latex modifier) and is supposedly very water resistant. If I were to purchase this for repairing cement decking would that be sufficient with a top coat of paint or water proofer?
I was told by a decking guy that the Jet cement (EMC combined with latex modifier) is sufficient to waterproof
crayola110 is offline   Reply With Quote
How many coats of elastomeric coating do we need? bayles Roofing/Siding 5 10-08-2010 02:47 PM
wrapped wood-grain coating peeling off steel door bendem Painting 2 03-27-2010 11:00 AM
Which coating to use ? desgnr Roofing/Siding 2 06-05-2009 12:00 PM
Rust-oleum EPOXYShield Coating? tripower Flooring 4 05-19-2007 03:20 PM
Reflective Coating on Flat Roof MelindaA Roofing/Siding 3 01-05-2006 06:08 AM
