Anyone Familiar With Flexitec Flooring? - Flooring - Page 4 - DIY Chatroom Home Improvement Forum
Old 12-20-2010, 08:02 AM   #46
It's incredible that this was posted. Just yesterday, I noticed a huge bubble under the Flexitec flooring that was installed in the kitchen back in the summer. Can't imagine why it bubbled so suddenly as nothing has changed in the kitchen. Either the glue let go or it wasn't glued all over to begin with. Would it help to put a hole in the bubble as one does with wallpaper?? It's probably too late to complain to the company installer.
maggiemay1013 is offline   Reply With Quote
Old 12-20-2010, 09:46 AM   #47
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 142
Flexitec bubbles are not usually caused by air. They are usually a result of too small an expansion gap.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 12-20-2010, 10:50 AM   #48
Maggiemay,
How do you like your floor otherwise?
Rusty,
Would poking the bubble with a pin deflate the air pocket?
We did not install our flooring ourselves. A floor guy put it in.
I posted previously that I have 100 SF of flooring to do, but it is 100 sq. yards.
Oakstable is offline   Reply With Quote
Old 12-20-2010, 11:47 AM   #49
Rewards Points: 142
Originally Posted by Oakstable View Post
Maggiemay,
Rusty,
Not usually. It is more than likely caused by lack of a proper expansion gap. Or something being moved on it. If it was properly installed, you pull it up and push the bubble out, when you put it back. If it was installed while the adhesive was still wet (it is supposed to dry first) you might try poking the bubble with a pin, but if it was installed wet, the adhesive acts like an epoxy, and the floor loses the avantage of easy removal. Most of the failures are improper installation. And the bubbles can come up several months later when it is improperly installed.
Old 12-20-2010, 12:13 PM   #50
Rusty,
I am debating between a sheet vinyl and an IVC for a family room, kitchen, etc.
I am looking at products with a 12-15 yr guarantee.
We are empty nesters on a ranch property so there is a lot of tracking in from outdoors, also two Dobies.
Which way would you go for the next flooring?
Old 12-20-2010, 12:42 PM   #51
Rewards Points: 142
If you can afford to do it right and will have it professionally installed, I would go sheet vinyl. If you have to do it yourself, I would use Flexitec.
Old 12-20-2010, 02:14 PM   #52
Rusty,
I plan to have it installed.
We have a ranch house and I am looking for the most realistic wood flooring I can find in a sheet vinyl.
Because I need 100 square yards, I am thinking of the mid-range pricing, like 12-15 yrs guarantee.
What brands should I be looking at?
TIA
Old 12-20-2010, 02:50 PM   #53
Rewards Points: 142
I am not familiar with all the patterns anymore. You will just have to look, all the companies make good products. You can find most of them on-line. Look for Mannington, Armstrong, Congoleum, Domco etc.
Old 12-20-2010, 02:59 PM   #54
I saw a Congeleum on line in a Timber Oak that looked good. Need to find it in a local store.
Also a Mannington Honey Ohio Oak that was in that range moe rustic look.
Our family room was once a garage with a breezeway inbetween it and the house. There is a lip going from former garage to breezeway space. Would you level that, sort of a ramp, with cement? or put a transition piece of wood and just let it be two different levels? I dont want the flooring to crack. Previous owner carpeted these two spaces.
Old 01-18-2011, 08:06 AM   #55
I generally like the floor but it never seems to be clean (in the kitchen). The floor was laid over new plywood subfloor and before the new cabinets were put in. I haven't yet put down the new quarter rounds (only been in since July. ha, ha) so don't know about the gap thing. Everything was fine after cabinets were in and appliances put in place. Nothing else changed for the past 6 months - nothing moved around, nothing added. The air bubbles just appeared suddenly 2 weeks ago. Only other thing is that the floor was installed during a very hot summer and the bubbles appeared on a very cold winter day, but the house was air conditioned and heated. So?? Can't figure it out.
Old 01-18-2011, 08:58 AM   #56
Rewards Points: 142
Don't know why the sudden bubbles, but you aren't supposed to put cabinets on top of any IVC vinyl.
Old 01-18-2011, 10:07 AM   #57
What should I expect to pay for labor to install 100 square yards of sheet flooring?
What does prep work involve?
Old 01-18-2011, 10:48 AM   #58
Rewards Points: 142
Labor prices vary widely from area to area. As far as prep, any imperfection as small as a grain of sand will show through resilient flooring. So whatever it takes to get it that smooth.
Old 01-18-2011, 11:18 AM   #59
One guy quoted me $7/SY not including prep work if I bought the material myself.
Another guy told me his labor only for my 100 square yards would run $2100.
Old 01-18-2011, 11:39 AM   #60
Rewards Points: 142
The $7 seems about right. But you need to get a quote on the prep. $2100 for just installing the vinyl is way out of reason IMO.
Flexitec flooring - need opinions taylort Flooring 6 02-25-2010 05:28 PM
Wood flooring in basement DIY4EVER Flooring 9 07-20-2007 01:04 PM
Hallway Flooring jay1000 Flooring 3 05-30-2006 06:04 PM
Gameroom basement flooring? PaulMcC Remodeling 4 03-09-2006 09:08 AM
IAQ and flooring. Briefly. Benhamcarpetguy Flooring 12 03-24-2005 08:53 PM
