Any Suggestions? - Flooring - DIY Chatroom Home Improvement Forum
Old 09-01-2010, 05:49 AM   #1
Any suggestions?
Hi there, I have a little problem regarding flooring.
It's a laminate floor but the first section near a door needs fixing or replacing (it had to be lifted for a plumbing issue).
The rest of the room is fine. I thought about replacing boards but most of the moulding is damaged.
would it ba a possibility to cut out a section and replace with maybe some rubber syle flooring / vinyl? The things is that I dont want to re-floor the whole room. (in fact it's a studio flat and the damaged area is by the front door)
Any suggestions would be great!
Thanks a lot
RichBee is offline   Reply With Quote
Old 09-01-2010, 07:01 AM   #2
This sounds possible to me. My only question is in regards to the transition from rubber to laminate. Is there a good location for this transition? If the transition is straight, you could use one of those metal strips typically used between carpet and hard floors.
oberkc is offline   Reply With Quote
Kitchen Cabinet Suggestions + General Kitchen Suggestions ffmariners Interior Decorating 3 08-16-2010 03:41 PM
Home Exterior Color Suggestions mcwolfe6 Interior Decorating 2 08-10-2010 08:20 AM
Fireplace Upgrade Need Suggestions joesmithf1 General DIY Discussions 7 01-18-2010 08:25 PM
Building a new deck......suggestions? thoughts? Rhizzlebop Building & Construction 38 06-24-2009 06:07 PM
Hip Vents for 12/12 pitch roof - any suggestions woodworker2000 Roofing/Siding 5 10-26-2006 11:31 AM
