Old 09-30-2008, 11:29 AM   #1
Any opinions on this product:
Minwax® Super Fast-Drying Polyurethane for Floors
A durable clear finish topcoat specifically formulated for hardwood floors. It is fast-drying, does not need sanding betwwen coats and levels to a smooth even sheen.
Is it true that it does not need sanding between coats? How can this be?
minneapolis1 is offline   Reply With Quote
Old 09-30-2008, 06:47 PM   #2
SM1
SandMasters ProFloorCare
SM1's Avatar
there are actually several finishes that do not need to be sanded between coats. it's called hot coating. you need to get the next coat on b4 the first one cures...usually within 12 to 24 hours to get whats called a chemical bond as opposed to the mechanical bond you get with inter coat abrasion. the only thing is you better have a surgically clean surface to coat if you plan on not sanding b4 the final
SM1 is offline   Reply With Quote
Old 09-30-2008, 08:10 PM   #3
I believe that they say that it is ready for the second coat within a few hours.
Uh, "surgically clean"????
using Lowes edge precision flooring Andy McDonald Flooring 68 03-17-2012 02:42 PM
glueless Vinyl product NoviceDIY Flooring 7 08-20-2010 06:52 AM
miele dishwasher.....any opinions? yummy mummy Appliances 11 03-17-2008 10:21 PM
