Antique Pine - Flooring - DIY Chatroom Home Improvement Forum
Old 06-14-2010, 09:50 PM   #1
antique pine
we had antique pine floors installed but the boards didn't fit snuggly together so i have spaces between the boards. What can i fill them with?
jolene is offline   Reply With Quote
Old 06-14-2010, 11:50 PM   #2
firehawkmph's Avatar
Rewards Points: 1,884
Jolene,
Most of the century homes I have been in with old pine floors have gaps here and there due to wood shrinkage. So if you were trying to replicate that, you did. Throw in a few creaks and you are right there. Seriously, do you have a lot of gaps, and if so, how big? Pictures would also help. Without seeing them, I normally wouldn't recommend filling them. It usually doesn't blend in well and a lot of times works loose due to seasonal wood movement. Also, what general area are you located?
Mike Hawkins
firehawkmph is offline   Reply With Quote
Why can't I find a good thatch rake or pine needle rake? carl1864 Landscaping & Lawn Care 5 06-05-2011 01:01 PM
HELP!!! Primed Knotty pine... needs to be unprimed! deke44 Painting 2 06-04-2010 03:44 AM
Pine problem Armando Franko Introductions 1 11-10-2009 06:37 PM
Finger jointed pine vs. clear pine Dan B Building & Construction 3 11-06-2008 11:03 PM
White Pine Hard-Wood floors? MrShadetree0222 Flooring 9 11-04-2008 08:24 AM
