Anti-skid For Epoxy Coatings?? - Flooring - DIY Chatroom Home Improvement Forum
Old 11-13-2009, 12:28 PM   #1
Anti-skid for epoxy coatings??
I'm getting ready to paint my garage floor with the DIY 2-part epoxy paint. I was wondering if I should opt for the optional 'anti-skid' additive.
Have any of you used the anti-skid additive? How did you like it?
Also, if I'm going to put a clear coat over the finish, should I mix the anti skid sand in the clear, or the epoxy?
Thanks guys, I appreciate your thoughts.
mopowers is offline   Reply With Quote
Old 11-14-2009, 10:00 AM   #2
Too Short? Cut it Again!
The additives for making epoxy coatings less slippery are just fine. Tape off and use them only where you need them if preferred or you will be stuck with the texture. Definitely mix them in with the expoxy.
Just curious, what material are you using that would ever require you to clear coat a new epoxy garage finish? I am not saying it is a bad idea but seems extreme to me? You do know you had better let that floor cure and outgass and vaporize a bit if you do attempt a top coat?
Old 03-25-2010, 02:16 PM   #3
Thumbs up
Mopowers,
We have been installing professional epoxy garage floors since 2004.
We use a product called Rhino Tooth in the sealer coat. It comes in various grits so you can get the amount of texture you are looking for. Look at www.vbpstore.com/rhino-tooth-non-skid-that-stays-suspended-vial.html
Patrick
California Concrete Restoration
http://www.squidoo.com/epoxygaragefloors
calconcrete is offline   Reply With Quote
skid loader vs dump trailer 4just1don Building & Construction 3 07-20-2009 04:14 AM
Skid Steer: Buy vs Rent DIY_JC Landscaping & Lawn Care 13 02-19-2009 09:26 AM
