Another Old Mastic Or Glue Question ... - Flooring - DIY Chatroom Home Improvement Forum
Old 09-13-2009, 09:26 AM   #1
Another old mastic or glue question ...
So, I pulled up my carpet and the padding behind it, and found brown stuff on the sub-floor. It didn't hold the carpet or padding down; it just seems to have been there for the previous flooring.
How concerned do I need to be about this? I'm not planning to scrape at it, but I think I saw bits on brown stuff on the back of the carpet as I was throwing it out the window. I was thinking about just prying out the tackboard, and covering the floor with a primer of some sort. I can't afford new flooring right now; I pulled it out as it's in my sons room, as he has a dust allergy.
I've got a HEPA vacuum; should I vacuum the floor?
Thoughts?
jacoite is offline   Reply With Quote
Old 09-13-2009, 01:48 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Could be old adhesive, could be deteriorated foam carpet backing, could be anything. If your son has dust allergies then what other choices do have other than to HEPA Vac it and get it out of there.
Any shellac will then seal the floor and make it more cleanable.
XXX
Old 09-13-2009, 01:53 PM   #3
So would simply putting a sealing primer on it be a bad idea, so as to encase whatever it is, and go from there?
Old 09-13-2009, 02:41 PM   #4
Tileguy
Bud Cline's Avatar
Rewards Points: 558
...you're not going to vacuum up the dust first?
XXX
Old 09-13-2009, 03:52 PM   #5
Sorry, yes, of course.
Old 09-13-2009, 04:07 PM   #6
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Vac and go I suppose!
Shellac or polyurethane should tighten things up for while.
XXX
tile man used mastic glue on entrance to shower keyesww Tiling, ceramics, marble 13 06-08-2010 04:39 PM
Old mastic or glue? matt700 Flooring 4 09-12-2009 03:56 PM
basement issues - tile, mastic, moisture pfisch Flooring 6 12-01-2008 01:35 PM
Reclaimed water pipe (Purple PVC) repair and glue question smcmurrey Plumbing 3 07-07-2008 09:49 PM
Question on WRONG glue used on ABS Roddy Piper Plumbing 12 12-29-2007 02:36 PM
