Another Knucklehead Considers Laying Tile Over Vinyl Flooring - Flooring - DIY Chatroom Home Improvement Forum
Old 08-23-2011, 02:37 PM   #1
BACKGROUND INFO: I'm laying ceramic tile in two bathrooms (43' square total). The house is 15 years old and the bathroom floors are concrete slab covered with embossed vinyl sheet flooring. I have no tiling experience but have researched online and called Mapei (who made the thinset that I had purchased based on sales associate's recommendation). Mapei suggested that I remove the vinyl and install on the concrete. I asked Mapei whether I could (not "should", I know that answer) install the tile over the vinyl. He gave me instructions for that as well.
THE ISSUE: I'm still on the fence about whether to install the tile over the vinyl or rip it up and install on the concrete. I want to make sure I know what steps are required for both methods so I can make an informed decision. And, of course, I will not put tile over the vinyl if it is cushioned or spot-glued.
QUESTION 1: How can I tell if my vinyl flooring is cushioned and/or spot-glued?
Note: The vinyl's pattern looks like 4x4 tile with shallow groves to simulate grout seams and pencil tip-sized craters on the "tile" to simulate stone imperfections. The floor has absolutely no give to it and no cracking or raised/bubbled areas.
QUESTION 2: Could you please take a look at my two options and let me know if I've got it right or am missing anything or taking any unnecessary/counter-productive step:
Alternative #1 - Install Tile Over Vinyl
1. Strip the vinyl with stripping chemical (to remove wax and gloss)
2. Neutralize stripping chemical
3. Apply Embossing Leveler (trowel)
4. Sand floor (rough grit)
5. Score floor with utility knife
Then I would use a Keraset/Keraply mixture as the adhesive
Alternative #2 - Remove Flooring and Install Tile On Concrete
1. Remove vinyl (cut with utility knife and use long-handled floor scraper)
2. Remove remaining glue (long-handled scraper/hot water)
3. Grind the concrete (any suggestions on the tool/machine to use?)
Then I would use Ultraflex 2 Thinset as the adhesive
Are these plans right? My main concern is that the adhesive adheres to the floor.
Any help is greatly appreciated. I've sort of Frankenstein-ed these plans together from various sites and Mapei.
Thanks in advance!
tacklingherlist is offline   Reply With Quote
Old 08-23-2011, 02:49 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Poke around and peel up some of the vinyl to see if it is perimeter glued or spot glued or fully glued. How hard is that?
Why would you need embossing leveller for installing ceramic tile?
Which Mapei product did you buy?
You are making this way too difficult.
Do ya think?
XXX
Old 08-23-2011, 03:47 PM   #3
Thanks for responding! Here are my responses:
Not hard at all. I will do that. Thanks!
I thought I needed that so that the floor was perfectly level. Right now there are grooves that simulate grout between tiles in the vinyl flooring pattern. Please tell me I don't need to level that, because that would be great.
I bought Ultraflex 2, which I will use if I opt to remove the flooring and install on the vinyl. But apparently it is not recommended for installing on vinyl. So if I chose to do that, the Mapei guy suggested I use a mixture of Keraset and Keraply. Is that right?
Again, thanks for the reply! I'm in the weeds here.
Old 08-23-2011, 04:19 PM   #4
Tile with Style
BlueStoneFloors's Avatar
You are overthinking this my friend. Here's how we would tackle it: Try to get that vinyl out, but if it won't come out I wouldn't use a stripper or anything that harsh. Most likely you can get at least the shiny layer off.
Then, after you scrape it the best you can (don't need to kill yourself trying to get it perfect) double coat it with RedGuard (HOME DEPOT-Custom Building Products) or similar product. This is a crack resistant membrane and will slow the mortar down from drying too fast. Then, I would use TEC Superflex mortar (720 psi bond rating), but some would consider that overkill. Your Ultraflex 2 (420ish bond strength) should be fine as well. You don't need leveler or any other fancy doodads, ceramic is the most porous type of man made tile, and concrete is the most stable subfloor. You're golden
Hell is 8 months of nothing but slate work...
BlueStoneFloors is offline   Reply With Quote
The Following User Says Thank You to BlueStoneFloors For This Useful Post:
Marbledust (08-25-2011)
Old 08-23-2011, 05:30 PM   #5
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Nope!
Means nothing!
You don't need to level that.
That'll work.
That'll work better.
Only because you choose to be.
See no reason to do that.
So is the vinyl.
So is the vinyl adhesive.
So is the vinyl felt backer.
Just don't try to climb around on the new tile anytime too soon.
H-m-m-m-m! Porcelain is a ceramic tile and porcelain is the least porous and least absorbing tile found routinely today I'm thinkin'.
I wouldn't.
What's the PSI Bond Rating of the Keraset/Keraply combination?
XXX
The Following 2 Users Say Thank You to Bud Cline For This Useful Post:
m1951mm (08-25-2011), ttr13r (08-25-2011)
Old 08-25-2011, 07:27 AM   #6
Keraset/keraply bonds with ceramic at 400-600 psi. I think I'm going to try that. Thanks to you both for the advice!
Old 08-25-2011, 07:48 AM   #7
if you leave the vinyl down and tile over it,you can change the tile in the future easy.I have removed tile over vinyl and it comes up easy.
the tool we use to grind concrete is a 7" angle grinder with a diamond disk cupped grinder wheel.real mess with dust or water going every where.to keep the dust down we have a 5 gallon bucket and tile sponge,one guy needs to squeeze water in front of the wheel to keep the slab wet while the other guy or gal grinds the glue up.
be shure to butter the back of the tile and the floor!
ps...we use a 5 1/2" angle grinder w/tile blade to cut out the door jamb and casing(creates smoke but does the job)or you can use a JAP saw.
Marbledust is offline   Reply With Quote
Old 08-25-2011, 09:47 AM   #8
Tile with Style
Except there's that little detail of how hot it's baked at, resulting in dramatically different porosity among other key differences. That's like saying Catholics and Christians are the same. Just because porcelain is a MEMBER of the ceramic tile family doesn't mean it's ANYWHERE NEAR THE SAME!! I realize you're technically correct, categorically speaking, but people need to know these 2 aren't the same for all installation purposes. Splittin' hairs, bud...
Old 08-25-2011, 03:40 PM   #9
What tool do I use to scarify the flooring? I was thinking that I'd use a utility knife and just make a bunch of cuts.
Old 08-25-2011, 08:19 PM   #10
Tileguy
JazMan's Avatar
Rewards Points: 422
That's a very good description of a cushioned sheet vinyl floor. Are there any seams? How wide is the vinyl?
No need for the embossing leveler, you're installing ceramic not vinyl.
Jaz
Old 08-25-2011, 08:26 PM   #11
Tileguy
Bud Cline's Avatar
Rewards Points: 558
OH GOOD!!! Now you are my Mentor. That's just what I friggen need is another damned boss looking over my shoulder and criticising my every move and comment.
Generally people don't give a chit about all that crap.
I wouldn't call the porosity difference dramatic necessarily. Ceramic tiles across the board range from around 3% to 7% porosity while porcelain comes in at .5%... Assuming you are equating porosity to moisture absorption.
That's dramatic?
Now whose splittin' hairs?
Hey by the way My Mentor. My wife snagged the garden hose the other day with the riding mower and wrecked the plastic hose-hanger for the second time this summer. Should I replace the hanger with another plastic hanger or should I use a steel hanger next time around? Or...should I just replace my wife? What say you boss?
XXX
The Following User Says Thank You to Bud Cline For This Useful Post:
ttr13r (08-26-2011)
Old 08-26-2011, 06:12 AM   #12
m1951mm's Avatar
Hey Bud,
[ My wife snagged the garden hose the other day with the riding mower and wrecked the plastic hose-hanger for the second time this summer. Should I replace the hanger with another plastic hanger or should I use a steel hanger next time around? Or...should I just replace my wife? What say you boss?[/quote]
Can I be first inline for a replacement???????? I promise I will not mow the lawn.
Mickey
Fantasy Walls and Windows
www.picturetrail.com/mickey51
m1951mm is offline   Reply With Quote
Old 08-26-2011, 08:49 AM   #13
Tile with Style
Woah...Are u off your meds or something? I'm just saying, it's confusing for people---"Hey honey, should we spend the extra money on the good mortar-it is porcelain tile...." says the wife. "No, that guy online said it's just a scam and it's really just ceramic, so buy the cheap stuff." WRONG!! Nuff said...No disrespect intended
Old 08-26-2011, 06:14 PM   #14
Tileguy
JazMan's Avatar
Rewards Points: 422
Hey Stoned,
Are you trying to teach Bud about tiles and how to? Forget it, you have no chance.
Jaz
The Following User Says Thank You to JazMan For This Useful Post:
ttr13r (08-26-2011)
Old 08-26-2011, 11:13 PM   #15
Tile with Style
Who u callin stoned? Oh wait, it is Friday night...
Slate or ceramic tile Flooring questions oldschoolboy Flooring 11 07-02-2011 09:49 PM
click lock wood flooring and tile guessingo Flooring 3 09-15-2010 10:56 PM
Vinyl self stick tile grout cesuark Flooring 3 09-06-2010 03:13 PM
Laying self stick vinyl tile cocean Flooring 6 06-14-2009 08:21 PM
HELP! Tile flooring question Marsy Flooring 1 02-16-2007 09:22 PM
