Angled Floating Wood Floor To A Top Stair - Flooring - DIY Chatroom Home Improvement Forum
Old 05-03-2013, 12:56 PM   #1
Angled floating wood floor to a top stair
I am installing a floating floor at an odd angle to my stairs, But i dont know how to install the top stair, I will be transitioning to carpet stairs after the top step.
Do cut the sub floor off (the bullnose part)? Do i leave it?
What type of piece do I get to attach it?
What are my options?
Have I done something stupid
note i have since the picture installed the floor just past the existing bullnose subfloor.
palabalo is offline   Reply With Quote
Old 05-03-2013, 04:46 PM   #2
Rewards Points: 20
You will have to get a bullnose trim piece. Then since you already installed your laminate at the stair edge you will need to cut it back to be able to put the bullnose in.
http://www.google.com/search?hl=en&g...FdXA4APzmIH4BA
ponch37300 is offline   Reply With Quote
The Following User Says Thank You to ponch37300 For This Useful Post:
jkk (06-29-2013)
Old 05-04-2013, 05:26 PM   #3
Rewards Points: 264
The right way to do this would have been to set the bullnose and then lay the flooring off of it. Now, as the other guy mentioned you will need to cut back your flooring and install the bullnose. You do not need to cut out the subfloor their. The manufacturer of the flooring you bought will offer these pre made pieces. Hope this helps.
Awoodfloorguy is offline   Reply With Quote
The Following User Says Thank You to Awoodfloorguy For This Useful Post:
jkk (06-29-2013)
Tags
floating floor , stairs
floating exterior wood stairs sierra1 Building & Construction 0 09-10-2012 06:40 AM
Floating floor - bullnose stair install pilotgirl Flooring 3 09-12-2011 09:57 AM
Wood Finish to Stair Rails propilot5000 Painting 1 01-09-2007 06:22 PM
Wood stair covering...pergo? DK75 Carpentry 6 11-02-2006 10:51 PM
Floating Wood Floors? dag Flooring 1 06-22-2006 09:40 PM
