Alternatives To Bullnose Tile - Flooring - DIY Chatroom Home Improvement Forum
Old 03-23-2011, 11:05 PM   #1
alternatives to bullnose tile
We have a small master bath I'm re-tiling with faux wood ceramic tile. I also want to use the tiles as the baseboard, but it's a pretty unique look and doesn't have any matching bullnose tiles. The problem I have is with the base of the shower. The old tiles I pulled were bullnose, but the new tiles will have the flat edge completely exposed when entering/existing the shower. Any suggestions for the proper finish? A bead of caulk on the top doesn't seem thick enough or look the best. Is metal edging an option? Any problems with the metal coming into contact with moisture?
nymlake is offline   Reply With Quote
Old 03-24-2011, 07:50 AM   #2
DIY staff
Rewards Points: 7,174
There are dozens of metal edging options-----Google --Schluter tile edging----They are one of many manufacturers.
Old 03-24-2011, 08:21 AM   #3
Stay-at-home GC
You might also try a rubbing stone/grinder to profile your edges and then stain them with permanent marker. Try a test piece
Can correctly identify Shinola 3 out of 5 times*
*Under ideal conditions
Some days, my Life needs a Rewind/Erase Button.
CplDevilDog is offline   Reply With Quote
Old 03-24-2011, 09:25 AM   #4
There are trim pieces, rail moldings, pencil rails, rope liners and others you could also consider for your bathroom ceramic tile floors. Also stop in a local showroom to try to get some ideas as well.
raycarboni is offline   Reply With Quote
Re-tiling a bathtub surround BillyB44 Remodeling 39 01-24-2011 07:10 PM
Bullnose Tile - how to do it? tjawed Flooring 4 06-02-2010 11:51 AM
Alternatives for fixing holes in tile roof felt Squash_Pro Roofing/Siding 4 05-13-2010 07:20 PM
tile threshhold to shower w/out bullnose suefoerob Flooring 2 03-14-2010 06:59 PM
Bullnose corner tile for backsplash golfgirl Tiling, ceramics, marble 5 03-05-2010 07:11 PM
