Already Installed Hardwood Floor Gaps - Flooring - DIY Chatroom Home Improvement Forum
Old 01-25-2011, 07:39 PM   #1
Already installed hardwood floor gaps
I just purchased a home and the home has hardwood floors but no casing around any doors and no base moulding. I started to install the casing and realised that the gaps between the hardwood floor and the wall are way way too large ( about an inch ! )
Unfortunately this is throughout the whole house, and I need to figure out a fix. Any suggestions on how to fill these gaps or any ideas what to do other than use large thick casing ( which would look horrible).
Thank you for any suggestions or help
Yoda0629 is offline   Reply With Quote
Old 01-25-2011, 07:45 PM   #2
You might want to consider a 5/8 baseboard and 1/2 shoe molding or 1/2 baseboard and 3/4 quarter round.
florpro is offline   Reply With Quote
Old 01-25-2011, 07:47 PM   #3
the Musigician
DangerMouse's Avatar
Are the edges of the boards flush with each other or staggered at the ends?
I might have an idea...
DM
Old 01-25-2011, 07:49 PM   #4
old guy contractor
tcleve4911's Avatar
Rewards Points: 530
How about standard 3/4" baseboard with a 1/2" base shoe?
tcleve4911 is offline   Reply With Quote
Old 01-25-2011, 07:56 PM   #5
@Danger they are flush throughout the house and actually looks real nice. Problem they did was leaving
the gaps just too large at the walls.
Unfortunately I thought of the base show moulding and the problem is my wife hates it
Are there any filler or anything like that out there for this type problem. It has to be somewhat common
Old 01-25-2011, 08:02 PM   #6
Experienced
Jackofall1's Avatar
At least the installed hardwood has a gap, a bit large at an 1", but only by a 1/4", better than not having a gap at all, where the floor will buckle in the summer.
Standard baseboard with a shoe moulding, works just fine, make sure you use spacers under the shoe and base to let the floor move under it.
At the doors not sure what you have, just gaps around the jams? you will have to get creative there, but it is possible to make it look nice.
Old 01-25-2011, 08:03 PM   #7
the Musigician
If it were me, I'd rip down some 3/4" x 1/2" strips from something that closely matches and glue them in place first, then put baseboards on. But I have a table saw and planer, etc. too.... might not be so easy for you.
DM
Old 01-25-2011, 08:06 PM   #8
honestly Danger that was what I was thinking. what material would u use for the strips ? Only problem I might have is it is inconsistent. some places are an inch wide other 1/2 inch. I will have to measure tomorrow1
Old 01-25-2011, 08:10 PM   #9
Experienced
Jackofall1's Avatar
You will require a gap between the flooring and the wall, some manufacturers recommend up to a 3/4" gap between the floor and a immovable object, so be careful about how much material you put in there, you may end up with floors that buckle in the summer.
Old 01-25-2011, 08:15 PM   #10
the Musigician
I have woods full of hardwood. Oak, walnut, whatever.... I'd just rip whatever sizes I need to keep a gap at the edges but have enough to be under the baseboards. I've been planing and routing my own baseboards and door casements all day today and yesterday. Oak... some fast drying poly and they look real nice!
See it here---> http://www.diychatroom.com/f49/oak-trim-93313/
DM
Old 01-25-2011, 08:44 PM   #11
Tileguy
JazMan's Avatar
Rewards Points: 198
I doubt that's feasible. Even if it were, I think in the end it would look like you did it yourself.
You need base + 3/4" quarter round. Even if you didn't have a wide gap, that is the way wood floors are finished.
Jaz
Old 01-25-2011, 09:07 PM   #12
Tileguy
JazMan's Avatar
Rewards Points: 198
Hey DangerMouse,
I'm getting a kick out of trying to figure out where you are located. (Or is it where you'd like to be?)
You didn't give a clue as to north - south or east or west, However two of the choices are in the middle of an ocean. Only two are on land and one location is no where near 3896 in elevation.
So, what's the prize?
Jaz
Old 01-25-2011, 09:15 PM   #13
Experienced
Jackofall1's Avatar
Originally Posted by JazMan View Post
Hey DangerMouse,
Jaz
Portage that canoe!!!!
Old 01-26-2011, 06:16 AM   #14
the Musigician
Hey DangerMouse,
Jaz
It's been done already....
Pvc gold???
post #'s 22-26
DM
Old 01-26-2011, 11:35 AM   #15
Tileguy
JazMan's Avatar
Rewards Points: 198
I checked that out and according to my 'puter those coordinates put you 22 miles away from the airport at a direction of 302 degrees. Out in the middle of a small lake or pond.
Does my Google Earth lie or is it because of magnetic north or something?
Jaz
Installing 3/4" Engineered Hardwood over Particle board New_Floors Flooring 4 01-26-2011 10:23 PM
Basic questions for hardwood or laminate install Demus Flooring 3 01-17-2010 07:38 PM
Hardwood floor buckling Dave E Flooring 25 12-18-2009 01:11 PM
Diagonal Hardwood Install Advice JDeFuria Flooring 7 06-29-2009 04:35 PM
5 Ways to carry on your hardwood floor shining brightly John_smith Flooring 3 02-24-2009 12:56 PM
