Old 08-25-2012, 06:31 PM   #1
allure vinyl locking challenge
This is really only a question for those who have worked with Allure vinyl locking, or an identical competing product. Pergo and other laminates don't work the same way.
Please see the picture. how would we negotiate these turns and bends?
Peter
JetJaguar is offline   Reply With Quote
Old 08-25-2012, 09:48 PM   #2
I see a few odd things.
Is this the longest straight wall? Back up and take another picture so we can see what the other wall looks like. In other words your suppost to be starting it on the longest wall and work toward the one with all the angles.
#2 Your not leaving any gap at the wall that I can see in that picture, with out a gap the flooring will buckle.
#3 One the flooring you have already laid you should be seeing the gray glue strip exposted, all I see is the top of the flooring, sure you not laying it backwards. You should not have to lift the strips to slide in the next piece, they go on top of it.
Below grade vinyl - hd allure? duke m Flooring 7 06-15-2011 11:55 AM
Vinyl sheet flooring & allure klmeenan Flooring 11 05-28-2011 01:39 PM
?laminate or allure vinyl plank flooring? suevwbug Flooring 0 05-09-2011 10:26 PM
Vinyl Siding Not Locking In Place Konfrst Building & Construction 13 11-17-2009 10:40 PM
vinyl sheet or tile (or allure) over old vinyl? thomase Flooring 8 06-30-2008 06:15 PM
