Allure Vinyl Flooring - Flooring - DIY Chatroom Home Improvement Forum
Old 03-20-2010, 02:41 PM   #1
allure vinyl flooring
Can a steam mop be used on Allure flooring??? Will it damage the adhesive???
caravan is offline   Reply With Quote
Old 03-21-2010, 11:21 AM   #2
Rewards Points: 1,574
Since steam is approx >200 degrees, I would think it would soften the glue and lead to problems. Read the maintenance info that they offer with the floor (see HD website if you lost it) and follow their instructions. Otherwise, no warranty.
bob22 is offline   Reply With Quote
Old 03-23-2010, 02:04 AM   #3
Rugs at importflooring.co
water is not the friend of any type of wood floor. That being said I think the allure floor has a wax impregnated tongue. Check your spec sheet that came with the floor or google it online. If you go ahead and use the steamer don't let it rest in one spot on the floor. keep it moving and lift it off when you are done.
shivangi is offline   Reply With Quote
Old 03-23-2010, 07:43 AM   #4
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 56
Allure isn't wood floor. It is vinyl plank.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 03-23-2010, 07:13 PM   #5
And I'd never steam a wood floor either.
Thoughts and opinions on "Trafficmaster Allure" flooring from Home Depot? zel Flooring 849 07-28-2015 01:31 AM
Thin set vs mesh porcelain floor tile over plywood subfloor and vinyl flooring Jerseygirl Tiling, ceramics, marble 49 05-23-2013 02:04 PM
Allure vinyl flooring TEAHMC Flooring 4 11-08-2009 04:06 PM
Trafficmaster Allure Commercial Confetti Dark Grey Vinyl Flooring (24 Sq. Ft. Per Cas bennyjets Flooring 3 08-09-2009 11:50 PM
vinyl sheet or tile (or allure) over old vinyl? thomase Flooring 8 06-30-2008 06:15 PM
