Allure Vinyl Flooring - Flooring - DIY Chatroom Home Improvement Forum
Old 05-28-2012, 08:34 AM   #1
allure vinyl flooring
I am installling the allure vinyl flooring tiles the kind that clicks together not the stick together kind does anyone have any suggestions on keeping the seams tight while working with this product. I am having alot of trouble keeping the seams tight. thanks for any help Terry
TerryCanning is offline   Reply With Quote
Old 05-28-2012, 08:45 AM   #2
Rewards Points: 13,300
You start making sure it's tight in one corner holding it up just enough so it does not make contact and move slowly pushing it toward the gap as you move along. You will see if you just apply steady pressure it will slide together.
If it's off try using a hair dryer to soften the glue and apply pressure.
By the way there's over 400 post on this one subject on this site, may want to take a look at some of them.
Yes you notice a smell like wet latex paint for a few days after installing it. And yes the smell goes away.
JetSwet (05-28-2012)
vinyl over vinyl flooring ri98 Flooring 3 11-08-2011 09:00 PM
want to remove recent vinyl flooring over asbestos subfloor fabster Flooring 5 05-04-2011 02:59 PM
Mats on vinyl flooring Rayma Flooring 1 02-18-2011 04:24 PM
Installing Allure vinyl planks Needs advice Flooring 0 09-04-2010 05:59 PM
remove grout from Allure vinyl flooring abkjr Flooring 2 08-02-2010 07:21 PM
