Allure Ultra Resilient Interlocking Planks - Flooring - DIY Chatroom Home Improvement Forum
Old 03-16-2011, 04:45 PM   #1
allure ultra resilient interlocking planks
Thinking of using this product over an existing ceramic tile floor. Will the grout joints telegraph through and be visible over time?
trixieb is offline   Reply With Quote
Old 03-16-2011, 08:24 PM   #2
woodman58's Avatar
If it is ceramic that is down more than likely it will telegraph thru over time. You can use a leveling compound to fill the joints. Make sure to scrape the floor smooth.
woodman58 is offline   Reply With Quote
Old 04-10-2011, 08:52 PM   #3
Veteran Rehabber
I've used Allure over vinyl and wood but not ceramic tile. The instructions say it will bridge gaps up to 1/8" wide and it really does what it says it will do. It covers screw and nail heads, vinyl patterns and gaps between sub-floor panels. If your grout lines are less than 1/8", then it should be OK.
CMHbob is offline   Reply With Quote
Trafficmaster Allure ULTRA! Planks wiley0714 Flooring 180 01-10-2017 09:35 PM
Thoughts and opinions on "Trafficmaster Allure" flooring from Home Depot? zel Flooring 849 07-28-2015 12:31 AM
Allure Ultra vinyl planks gkschet Flooring 1 04-03-2012 10:48 AM
Installing Allure vinyl planks Needs advice Flooring 0 09-04-2010 04:59 PM
Laminate vs Allure Vinyl Planks okie03 Flooring 0 03-14-2010 07:44 PM
