-   -   allure ultra resilient interlocking planks (http://www.diychatroom.com/f5/allure-ultra-resilient-interlocking-planks-98629/)
trixieb 03-16-2011 05:45 PM
Thinking of using this product over an existing ceramic tile floor. Will the grout joints telegraph through and be visible over time?
woodman58 03-16-2011 09:24 PM
If it is ceramic that is down more than likely it will telegraph thru over time. You can use a leveling compound to fill the joints. Make sure to scrape the floor smooth.
CMHbob 04-10-2011 09:52 PM
I've used Allure over vinyl and wood but not ceramic tile. The instructions say it will bridge gaps up to 1/8" wide and it really does what it says it will do. It covers screw and nail heads, vinyl patterns and gaps between sub-floor panels. If your grout lines are less than 1/8", then it should be OK.
