I have just put down some TrafficMaster Allure Ultra flooring in a small bathroom floor directly over a concrete slab (no vapor barrier or underlayment used). When I step on it the floor makes a clicking noise. All the seams are nice and tight. It just seems to be making the clicking noise against the slab. Any suggestions on how to get rid of the clicking noise?
Options I've thought of:
Can I remove the floor and put a 6 mil vapor barrier down to get rid of the clicking?
Should I put a 7/32 layer of luan down btwn the slab and vinyl planks?
I've heard someone put roofing felt (tar paper) down to remove the clicking noise. Is that a good option?
Lumber Liquidators sells an underlayment for floating vinyl floors. Is that an option? Allure says NOT to use a foam underlayment though.
Should I use an adhesive remover on the slab to try to make it perfectly smooth?
Background information:
SE Michigan, Ranch home
First floor bathroom over a concrete slab
Slab previously had old vinyl tiles that were removed.
Floor was swept/vacuumed before applying new flooring. I didn't use any adhesive remover
on the floor once the vinyl tiles were removed. It wasn't sticky and was fairly smooth but maybe not smooth enough.
The instructions for Allure Ultra say NOT to use any foam underlayment.
