Allure Ultra - Flooring - DIY Chatroom Home Improvement Forum
Old 04-16-2011, 08:34 AM   #1
allure ultra
can you use the allure ultra resilient interlocking planks on a concrete inclosed back porch that is not heated?
ronald reffett is offline   Reply With Quote
Old 04-16-2011, 09:40 AM   #2
Rewards Points: 1,528
From install manual from HD site at: http://www.homedepot.com/catalog/pdf...adb28302c3.pdf
CAUTION: Do not install allure over
carpet or any foam underlayment. This
product is not suitable for any outside use,
sunrooms/solariums, saunas, or rooms that
have the potential of flooding. We also
highly recommend you do not install in
rooms or homes that are not temperature
controlled. Exposure to long term direct
sunlight can cause damage to your floor.
Also:
Subfloor preparation:
The sub floor surface must be smooth,
flat, dry, clean and solid. Carpet staples
or adhesive residue must be removed to
insure proper installation.
Subfloors should be flat within a
tolerance of 1/8” (3mm) over a span of
4 feet. Any unevenness over 1/8”
(3mm) must be sanded down or filled
with a floor leveler. Voids or humps in
the sub floor will prevent allure from
locking properly.
Subfloors must be carefully checked for
moisture problems. allure ULTRA is
waterproof. It is NOT a water-proofer.
Any moisture problems need to be
addressed prior to installation. New
concrete floors need to cure for a
minimum of 60 days.
bob22 is offline   Reply With Quote
Trafficmaster Allure ULTRA! Planks wiley0714 Flooring 180 01-10-2017 10:35 PM
Allure Ultra vinyl planks gkschet Flooring 1 04-03-2012 11:48 AM
allure ultra resilient interlocking planks trixieb Flooring 2 04-10-2011 09:52 PM
Behr Premium Plus Ultra beachnik Painting 2 06-15-2009 05:36 AM
Trafficmaster Allure and Concete Sealer Alex3D Flooring 1 03-24-2009 07:26 AM
