Allure Traffic Master Question..... HELP!!!!! :) - Flooring - DIY Chatroom Home Improvement Forum
Old 01-15-2012, 07:33 PM   #1
Allure traffic master question..... HELP!!!!! :)
I will be installing 650 sq ft of this, there are 2 doorways... from kitchen to living room, and bathroom to hallway. I plan to install all the tiles in the same direction east to west.... do I still need to do a transition strip in the doorways or is this just for changing directions in tile layout? Also..... I am installing this in a double wide..... wondering about the middle where the 2 halves join together..... There has been some movement over time..... wondering if there should be something there as well.. anyone else install this or similar product in a mobile home? Any thoughts on this?
TammyF is offline   Reply With Quote
Old 01-15-2012, 07:36 PM   #2
Rewards Points: 582
if you can do it and have it look good go for it...I would...no you don't need one...
Old 01-15-2012, 07:39 PM   #3
Rewards Points: 13,744
Going to be tricky for a first timer but it can be done with no stips.
Take your time whaen setting the seams. Some times if there a little off you have to wiggle them a little bit while lifting them slightly.
Old 01-15-2012, 07:47 PM   #4
I am a bit nervous about it but not scared!!!
@ Joe..... I think I saw on another post that you have this brand in your home...... how do you like it? Wondering about smell.....
Trafficmaster Allure ULTRA! Planks wiley0714 Flooring 180 01-10-2017 09:35 PM
Allure traffic master from hd PorgyLuvzBess Flooring 1 08-15-2011 10:10 PM
traffic master alure metalformer Flooring 7 01-24-2011 04:34 PM
Allure Traffic Master ckelly Flooring 1 09-22-2010 12:22 PM
Home Addition's foundation question? chai3341 Building & Construction 13 01-01-2009 11:46 PM
