allure LOCKING Innovation?
I wish I had known that the allure "LOCKING" system was defective...
Could have saved alot of wasted time and money :mad:.. |
Who says it's defective.
I have two houses with it and have had 0 issues with it. Any time I've seen it fail was when someone did not roll the seams or they left no gaps on the outside edges. |
I think your talking about the flexible allure? The type I used is the 4ft x 71/2 in, hard vinyl boards, It was new house I covered 600 sq ft... I also used the allure your talking about in the bath rooms (3) I did use a roller, but the joints on that system are not perfect!! I will say the flooring was installed as per instructions, when finished it looked perfect but after a few months the defects started to appear.. Unfortunately its looking like I will have to replace the flooring... To lift it and reinstall is a major job, and experiencing the defects I'm sorry but I have lost confidence in this system!!! THE ADD IS ON THIS SITE , FROM HOME DEPOT!! |
Allure Locking looks like Allure Ultra. I haven't had the problem you've experienced.
So what exactly was the problem? Did you contact the manufacturer? If it is truly defective they should really replace it. What is the subfloor? Why did it fail? Professional install or DIY? Pictures?
I am looking at putting down 700 square feet of the Allure Ultra and come across complaints like this, but they really do not help anyone without the detail. Every product or service in the world falls into the category "you should not buy" because someone on the internet had a vague complaint. |
I installed ~250sq ft of Allure Ultra in our kitchen a couple of months ago. It's been excellent so far. The subfloor was smooth/flat and I paid a lot of attention to make sure the pieces were clicked together with zero gap.
Do it right and most likely there will be no problems. We like it so much we're most likely putting it in the finished attic space, probably another 400sq ft or so. |
I installed about 100 sq ft of Allure Ultra and my only complaints are that it was difficult to get the pieces locked together and it's hard to install it around objects.
Allure Ultra, I think that I must have had a defective box..
Cos the defective planks, joints add up to one box, unfortunately they where mixed all together when installed, obviously some of the planks are not perfect, so you make adjustments.. area covered appox - 1000 sq ft.. The floor was perfect when finished, I was very impressed with this product, also some friends where talking of using Allure Ultra.. The floor has now been installed for 2 years, first separations started within the first 6 months, I was able to get them back together, (my home is a new build) so the floors where level .. The defects I mean , the planks can be pushed together slide apart without locking, the locking system has failed...smaller areas like, dining room and kitchen OK, but hallway , living room (bigger areas) I have separation, I have informed Home Depot about this problem.....http://www.diychatroom.com/images/icons/icon9.gif |
| All times are GMT -4. The time now is 05:01 AM. |
