Allure Lisbon Light And Dark Cork - Flooring - DIY Chatroom Home Improvement Forum
Old 04-03-2011, 12:42 AM   #1
allure lisbon light and dark cork
I am planning on updating our kitchen, I want to try the allure planks, I was planning on putting it right over the vinyl on the floor now. the vinyl on the floor now has fake grout lines that create depressions in the pattern, do I need to fill these in before I put the allure over it? Also I am really interested in the lisbon light and lisbon dark cork, has anyone used either? and do they show scuffing or marks easier than the wood look?thanks.
baileyboy is offline   Reply With Quote
Old 04-03-2011, 06:42 AM   #2
woodman58's Avatar
The glue on Allure has improved over the past few years. I'm not sure if the libson cork is a vinyl or real cork. The Home Depot will stand behind their products. So, I say go for witch ever pattern you like.
woodman58 is offline   Reply With Quote
Old 04-05-2011, 01:56 PM   #3
Answer to grout line question
Any embossing or grout lines exceed 1/8 you must level the floor first with a cementitious/leveling patching compound.
allure pro is offline   Reply With Quote
Old 04-10-2011, 09:31 PM   #4
Veteran Rehabber
I use Allure in my rentals and rehabs. I've installed Allure over vinyl tile several times. The Allure material is stiff enough to prevent the vinyl pattern from telegraphing through to the surface. The instructions say it will bridge gaps of 1/8" and it really does do what it says. As long as your grout lines are less then 1/8" wide, no leveling is needed. If you are concerned, look at the commercial grade version. It is thicker and will handle bigger imperfections in the subfloor. BTW, this is not real cork. It is molded vinyl planks that look like cork. I recommend the darker pattern. It hides the tiny gaps between planks better. You can never get the planks to align perfectly no matter how careful you are. A tiny gap will show with the lighter tile as a dark line about the width of a human hair.
CMHbob is offline   Reply With Quote
Dark over light...Do I need tinted primer? melissaandkris Painting 17 09-09-2011 11:43 AM
Sorority House Light Fight Samson&Delilah Electrical 18 10-01-2009 12:39 PM
painting dark from light, how many primer coats? Miss Molly Painting 6 05-20-2009 11:04 AM
I Hate Ice Stubbie Off Topic 20 12-21-2008 12:41 PM
Separating Fan and Light Switches GeauxCajuns82 Electrical 11 08-26-2008 01:03 AM
