Allure Laminate Flooring 12x36 Planks - Flooring - DIY Chatroom Home Improvement Forum
Old 09-02-2012, 05:16 PM   #1
Allure laminate flooring 12x36 planks
I accidently spilled paint thinner on a small portion of my Allure laminate flooring that has the adhesive strips to hold it together. How do I repair the finish? The paint thinner ate right through the urethane and the stain. Can it be repaired or do I have to tear out the whole panel? The area is about 2" x 2".
jgrepasi1975 is offline   Reply With Quote
Old 09-02-2012, 05:28 PM   #2
Rewards Points: 13,712
Your pretty much out of luck on this one and you looking at a whole new floor.
Impossible to just repair or remove that one piece.
Once the bonds been broken even if you use a heat gun it's not going to ever stick again.
Old 09-04-2012, 02:32 PM   #3
Rewards Points: 610
Lool up MINWAX Finishes ..they have a stain that goes on similar to paint..just sand surface a little and apply..will take a few coats..just did our previously finished railings....from blonde oak to dark brown...turned out great and leaves a hard shine...You will have to be careful to choose a suitable color.
techpappy is offline   Reply With Quote
Trafficmaster Allure ULTRA! Planks wiley0714 Flooring 180 01-10-2017 09:35 PM
Is there a durable laminate flooring for kitchens? samalex Flooring 5 11-03-2010 02:55 PM
Laminate vs Allure Vinyl Planks okie03 Flooring 0 03-14-2010 07:44 PM
Basement Flooring: Laminate material atm Flooring 1 06-30-2009 10:34 AM
