Allure flooring seems lifting up
Call Allure. They will express deliver a small bottle of Allure Adhesive with instructions.
Basically, heat the area with a hair dryer to soften the planks. Lift up the section of plank with a flat blade scraper. Drop a drop of adhesive about
every inch (or less) along the adhesive section closest to the edge.
Push the vinyl back down and place a weight on the section for 24 hours.
Once down, it will stay down.
I actually used a small hammer and a magazine to tap the vinyl back down. Once it was warmed by the hair dryer, it expands slightly so it didn't pop back in place quickly.
I placed the magazine on top of the vinyl to protect the surface as a gently gave small taps to force the plank back down into place.
It works and I haven't seen any more lifting where the adhesive was applied.
