-   -   Allure flooring seems lifting up (http://www.diychatroom.com/f5/allure-flooring-seems-lifting-up-152507/)
Eloi 08-03-2012 10:36 PM
How to correct the problem with allure flooring lifting up ?
joecaption 08-03-2012 10:38 PM
Is it in the middle or only along the walls?
Eloi 08-03-2012 10:43 PM
in the middle mostly but here and there in the rooms . lifting up in many places on over concret floor and over old venil floor
joecaption 08-03-2012 10:51 PM
Was there a vaper barrier laid before the flooring went down?
How long has it been down?
And what's a venil floor?
Eloi 08-03-2012 10:51 PM
It is a rental house and I need to fine a good solution quickly befor re renting .
Eloi 08-03-2012 10:55 PM
no vapor barier , I instaled the allure flooring over the old vinyl flooring .instaled in good condition dry and even .
Eloi 08-03-2012 10:58 PM
laid down 4 and 5 days ago
joecaption 08-03-2012 11:09 PM
http://www.installertools.com/cgi-bi...alogno=05-349S
Pick up one of these, Lowes and HD will have them in the flooring area and see if that takes care of it.
I've laid a ton of Allour and never had a seam lift.
Are you 100 % sure you did not install it tight to the walls. If so it's going to keep bucking.
Eloi 08-03-2012 11:20 PM
thanks I was thinking of adding glue on the seams that are lifting up with something heavy until it dry . what do you think ?
Eloi 08-03-2012 11:25 PM
I left 1|8 of an inch by the walls .
joecaption 08-03-2012 11:28 PM
Go back and read the directions it should have been more.
I would not add any glue, it may react with the glue already and nothing will stick.
Eloi 08-03-2012 11:32 PM
I have no baseboard by the walls yet is it still time to cut of more by the walls ?
joecaption 08-03-2012 11:38 PM
You can try, but look on the directions on there web site first to see how much should have been left.
It's been over a year since I've installed any and I forget the exact measurement.
mitchellwu 08-20-2012 03:16 PM
Call Allure. They will express deliver a small bottle of Allure Adhesive with instructions.
Basically, heat the area with a hair dryer to soften the planks. Lift up the section of plank with a flat blade scraper. Drop a drop of adhesive about
every inch (or less) along the adhesive section closest to the edge.
Push the vinyl back down and place a weight on the section for 24 hours.
Once down, it will stay down.
I actually used a small hammer and a magazine to tap the vinyl back down. Once it was warmed by the hair dryer, it expands slightly so it didn't pop back in place quickly.
I placed the magazine on top of the vinyl to protect the surface as a gently gave small taps to force the plank back down into place.
It works and I haven't seen any more lifting where the adhesive was applied.
