Allure Flooring - Flooring - DIY Chatroom Home Improvement Forum
Old 12-06-2010, 09:15 AM   #1
Allure flooring
Just purchased allure flooring for my basement. The cement floor is not level and I am wondering if anyone who has had experience laying this type of flooring can respond to the need for a level floor and any problems faced with laying it upon a plastic moisture barrier.
diyrt is offline   Reply With Quote
Old 12-06-2010, 11:02 AM   #2
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 84
Go to search and type in "allure". You wil find threads about problems with this product.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 12-09-2010, 10:33 AM   #3
HD Social Media
AskMrJay's Avatar
Hey there diyrt,
Mr. Jay here with The Home Depot. Hopefully I can help with some of your concerns on this install.
As far as having the floor level, the tolerance of the product is about
3/16th of an inch over a 10' span. It is a relatively forgiving product, but I would address any issues over that amount.
For the vapor barrier, the only problem that I would see is that the sub wouldn't really be able to breath through the allure, and may mold on the barrier over time. So while you theoretically could lay right over it, I would look into getting a water-proofer of some kind down on the floor first if you really feel that it's going to be an issue. Have you had problems with it before, or tested it recently for moisture?
Hopefully that helps you out and the install goes smoothly :D let me know if you have further questions~
AskMrJay is offline   Reply With Quote
Thoughts and opinions on "Trafficmaster Allure" flooring from Home Depot? zel Flooring 849 07-28-2015 12:31 AM
Allure Flooring in My Garage Milne Flooring 12 10-30-2010 12:38 AM
Allure flooring and prep work bstreyle Flooring 1 04-12-2010 03:43 PM
Allure Flooring from Home Depot Kitchen Flooring 0 08-23-2009 09:33 PM
Trafficmaster Allure Commercial Confetti Dark Grey Vinyl Flooring (24 Sq. Ft. Per Cas bennyjets Flooring 3 08-09-2009 10:50 PM
