Allure Flooring - Flooring - DIY Chatroom Home Improvement Forum
Old 12-12-2009, 04:35 PM   #1
Allure flooring
I'm thinking about using this flooring over a 10' x6' radiant heated kitchen floor. Could the heat cause problems? It can get pretty warm.
Dmadson is offline   Reply With Quote
Old 12-13-2009, 01:52 PM   #2
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 52
Did you ask HD? There are a bunch of threads on here about Allure/Konecto. This has probably been covered.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
rusty baker is online now   Reply With Quote
Old 12-14-2009, 01:59 PM   #3
Angry
Allure flooring
Issue: Humidity problems with Allure vinyl flooring from Home Depot. I got on this forum to find out if anyone else has had humidity problems after installing Allure in their garage. Here's my experience. I live in Central Florida and have had Allure Diamond Plate Graphite (gray) flooring installed in my concrete slab garage (~21'x24') since Feb 2009. Since I've installed this flooring, the tool-steel of most of my hand tools, miter saws, table saw, drill press, stainless steel cabinet doors, and even my motorcycle has severe rust and/or corrosion (i.e., white oxidation). I've lived in this house for almost 15 years and have never had a rusting problem in my garage, even with pool chemicals stored in my garage. The only thing that was a drastic change to the environment in my garage was the installation of this flooring. Before I put the flooring down I cleaned the slab with TSP and allowed it to dry thoroughly. I also trimmed the flooring so the threshold would be inside the garage when the main garage door is shut. The only thing I did that might have affected the moisture evaporation/drainage is I sealed the edge of the floor and threshold at the main garage door with caulking to prevent water from seeping underneath the floor if it starts to rain with the garage door up (until I closed it which is always right away).
I've read about several people reporting moisture problems in a basement, but has anyone heard of moisture problems in a garage after installing Allure? The rusting problem has ruined hundreds of dollars worth of tools and equipment. I'm ready to yank up the flooring and pitch it in the garbage. There goes over ~$1300 bucks down the tubes just in the cost of the flooring alone.
davidwajr is offline   Reply With Quote
Old 12-14-2009, 02:00 PM   #4
Do a search on this forum for "allure" & read the issues people have had
Allure Flooring from Home Depot Kitchen Flooring 0 08-23-2009 10:33 PM
Trafficmaster Allure Commercial Confetti Dark Grey Vinyl Flooring (24 Sq. Ft. Per Cas bennyjets Flooring 3 08-09-2009 11:50 PM
