Allure Flooring - Flooring - DIY Chatroom Home Improvement Forum
Old 10-23-2011, 10:23 PM   #1
Allure Flooring
I want to replace about 1000 sq ft of carpet in walk out basement. Looking at vinyl as I'm afraid to use wood or wood laminate below grade, on concrete. I have no moisture problems with carpet but with concrete, I assume mold is possible. Are moisture inhibitors pretty reliable in this situation? I like the wood plank look but the planks are only 2mm think. I have a concern that, when I pull up the carpet (glued down) the surface will have rough spots from glue residue and also some pressure cracks in the concrete. Assuming there has been some settling over 25 years, has anyone installed this over an old concrete floor? Do the pressure cracks show though? Should I consider the commercial flooring (thinker stuff) even though that doesn't come in wood grain pattern? Also, can this stuff be applied to stairs? What do you put on the edge of the tread? Is there any product besided those metal corner bead strips?
Mojo 716 is offline   Reply With Quote
Old 10-24-2011, 02:37 AM   #2
Check the third paragraph here
http://www.konectousa.com/files/install_checklist.pdf
Alex5567 is offline   Reply With Quote
Thoughts and opinions on "Trafficmaster Allure" flooring from Home Depot? zel Flooring 849 07-28-2015 12:31 AM
Allure flooring bdaylady Flooring 2 08-06-2011 07:46 PM
Allure flooring and prep work bstreyle Flooring 1 04-12-2010 03:43 PM
Allure Flooring from Home Depot Kitchen Flooring 0 08-23-2009 09:33 PM
Trafficmaster Allure Commercial Confetti Dark Grey Vinyl Flooring (24 Sq. Ft. Per Cas bennyjets Flooring 3 08-09-2009 10:50 PM
