Old 07-22-2011, 09:30 PM   #1
allure flooring
interested in the allure trafficmaster planks that are water resilent . have an old vinyl floor and it discolored. i was told ,my floor must be sweating or getting water from slab could i use this
brand
rtreadway is offline   Reply With Quote
Old 07-22-2011, 09:36 PM   #2
Pro Flooring Installer
rusty baker's Avatar
allure flooring
Go to search and type in allure. You will find hundreds of pros and cons.
"I'm twisted, not sick. Sick implies, I'll get better"
Semi-Retired Installer
Installing since 1973
Old 07-23-2011, 01:06 AM   #3
Tileguy
Bud Cline's Avatar
allure flooring
This place is full of information about Allure.
Old 07-23-2011, 06:48 AM   #4
woodman58's Avatar
allure flooring
If you have vinyl and the floor is turning dark I would remove the floor. If vinyl discolors from underneth it is most likely mold. This is a bad condithion to cover up. I would take it up, clean the floor with bleach (vintilate while doing this), and seal the floor before putting a new floor down.
woodman58 is offline   Reply With Quote
Thoughts and opinions on "Trafficmaster Allure" flooring from Home Depot? zel Flooring 829 06-10-2013 07:59 PM
Vinyl sheet flooring & allure klmeenan Flooring 11 05-28-2011 01:39 PM
Allure flooring and prep work bstreyle Flooring 1 04-12-2010 04:43 PM
Allure Flooring from Home Depot Kitchen Flooring 0 08-23-2009 10:33 PM
Trafficmaster Allure Commercial Confetti Dark Grey Vinyl Flooring (24 Sq. Ft. Per Cas bennyjets Flooring 3 08-09-2009 11:50 PM
